BIKELAND > FORUMS > ZX-14.com > Thread: Sprocket socket NEW TOPIC NEW POLL POST REPLY
zx14fan
posted January 15, 2010 03:47 PM
Sprocket socket
Do they make a special socket for the front drive sprocket?
Bawls
re-learning to ride
posted January 15, 2010 04:07 PM
just get a 6pt impact socket for it. I used a cheap one from harbor freight.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
Douglas Home
posted January 15, 2010 04:08 PM
I used a 1 1/16 inch , deep impact , six sided socket .
I think that is 27mm???
Doug Mackay Australia
gilberjj
Friend of Fast
posted January 15, 2010 05:13 PM
just curse a lot when you're removing it. That's what helped me!
zx14fan
posted January 15, 2010 07:28 PM
I HAVE A LONG BAR AND WILL KEEP THE BREAK ON SO IT SHOULDNT BE A BROBLEM.
posted January 15, 2010 08:02 PM
That nut is on so tight just holding the brake dosent always work. Hopefully yours isn't as tight as some of ours. Get a 2x4 ready to stick in the rim to help hold it.
zixxer14
Damn that was Quick
posted January 15, 2010 09:02 PM
It's a 27mm, use only a 6 point socket, long breaker bar & someone to hold the bike from moving when that sucker breaks loose. The 2x4 is optional if the brake doesn't hold. Cursing & blood required.
LOCK 2121
posted January 15, 2010 11:08 PM
Heat the nut first , not enough to ruin the oil seal, a littel hot wrench goe's along way !
BobC
posted January 16, 2010 02:09 AM
What they all said, it's worth repeating, make sure you use a six-sided socket. It bears on the flats of the nut and will never round off the corners.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
SixSixoh6
posted January 19, 2010 02:16 PM
Hmm, mine came off fairly easy with my impact. 100psi set on the compressor, running through a skinny air hose. Few hits and it came right off. Bike wasn't even in gear...no tire on either.
kawasakijockey
posted January 19, 2010 02:29 PM
Well the bad-ass that tightened mine on must have been off the day your's was done..
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
SixSixoh6
posted January 20, 2010 12:20 AM
Yeah I was quite puzzled as to why mine came off so easy...hopefully they didn't slack on tightening on other things..
0.20960998535156 seconds processing time
