BIKELAND > FORUMS > ZX-14.com > Thread: water in the gas tank NEW TOPIC NEW POLL POST REPLY
zx6reaker
D&D's, Frame sliders, pcIII
posted December 05, 2009 11:46 PM
Has anyone had troubles with water in there gas tank? I'm not sure yet if that's what happened but the bike started running funny today (sounded like it was sputtering and missing like a fouled plug but intermittant.) Is there something I can add to the tank to get rid of the water or just drain it and see if anywater was in it? It's been raining here in Jax for two days now and I've been riding, that's why I think it's just water. Any and all help is appreciated in advance.
So...what's the best way to drain your tank? with the fuel pump or...?
Loud pipes and bright lights save lives.
zxbob
posted December 06, 2009 04:35 AM
Removing the fuel tank, then removing the fuel pump is the sure was to get it 100% drained,
but you can try siphoning it out.
I have also heard rubbing alcohol works because it mixes with both water and gas.
Bob
Sticks_n_Stones
posted December 06, 2009 06:22 AM
+1 on rubbing alcohol as the cheap alternative: or just go to the auto parts store and get any of a long list of fuel additives that can so-called 'dry out' the fuel tank by absorbing the water and dispersing it into the fuel so that it can be burned up evenly without the sputtering or dying of the engine.
However, if that works then you still have a problem: most likely involving the fuel filler area leaking the water into the tank instead of draining it away. Blow out your vent line with compressed air then, that should solve it.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
posted December 06, 2009 08:47 AM
Try Sentry Fuel Additive
zx6reaker
posted December 06, 2009 09:55 AM        Edited By: zx6reaker on 6 Dec 2009 18:04
Don't know if I should start a new thread or not, but I don't think it's water in the tank anymore. Cranked it up to see if I got all the water out of the tank and drove it around for about 5 min and it did fine. Then it started the same thing again. sputtering and then a large cloud of white smoke. now just turns over, will not start. I didn't hear any knocking or unusual. parked it in the garage and noticed that it was leaking. Looks like fuel oil mix and smells heavily of fuel. I checked wear it was coming from and seems to be the valve cover gasket in the front.
Does any one have any suggestions? I am guessing now that I have to replace the valve cover gasket. Never done this before but I'm fairly mechanical. any help or advice or does anyone live around the Jax area that could help.
Bawls
re-learning to ride
posted December 06, 2009 10:08 AM
maybe you can take it to smokin' and have him work his voo-doo witch magic on it?
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
zx6reaker
posted December 06, 2009 10:09 AM
Is he near Jacksonville Fl?
posted December 06, 2009 10:10 AM
highly recommended!!
posted December 06, 2009 10:11 AM
St Pete, not that long a ride, plus he has got a dyno.....
zx6reaker
posted December 06, 2009 10:13 AM
Can't ride but I can get a trailer
Flame On
Fuel Air & Spark
posted December 06, 2009 10:32 AM
No never heard of that on the 14 I run Lucas gas stabilizer every few tanks
77 RD 400
80 GS1000 GT
06 ZX14
Bawls
re-learning to ride
posted December 06, 2009 10:42 AM
maybe a long shot, but if you have a PC3 on it did you check your ground wire?
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
zx6reaker
posted December 06, 2009 10:44 AM
I didn't look at it. However it may cause it to run funny but shouldn't have anything to do with the leaking.
Douglas Home
posted December 06, 2009 10:55 AM
Havent just cleaned and oiled the air filter??
Doug Mackay Australia
Sticks_n_Stones
posted December 06, 2009 11:00 AM
blown head gasket. Sorry to tell you that, but if it smells like a duck and looks like a duck... its a duck.
Blown head gasket sucking water (white smoke) and pressurizing the engine (which blows the valve cover gasket). Of course, thats on the assumption the 14 HAS a head gasket. I recall something about the head and gearbox being one unit or some such thing? Time to wait for smoking or 1bad to chime in with there expert opinion.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
Jason Gillum
posted December 06, 2009 06:47 PM
I would go with the PC3 ground. Run a wire from the battery ground, or ground lug outside battery box, to the PC3 ground. You can route the wire through the stock zip ties on the fuel rail. Don't cut the PC3 Wire, it will void the warranty. Just a thought
Brock's Performance...
posted December 06, 2009 09:47 PM        Edited By: SteveWFL on 7 Dec 2009 05:48
That exact thing happened to me on my 14 and it was the ground on the PCIII. Not sure if thats your prob but for the two seconds its worth might be worth checking
zx6reaker
posted December 06, 2009 10:02 PM
The pcIII ground wouldn't explain the fluid leaking from the engine or the whitish smoke. I wish it were that easy though.
Old Guy
posted December 07, 2009 07:32 AM
White smoke and no comment on gas smell, its a duck.
Sorry ...,
Living the good life...,
On a XZ !!!!!
Tsukigi stainless full system
pcIII w/custom map
NO freakin flies!!
GP suspension forks
Penske rear shock
Rich's custom seat
good stuff
Hurricane
posted December 07, 2009 09:01 AM
+1 Head Gasket
Sticks_n_Stones
posted December 07, 2009 11:07 AM
+1 Head Gasket
+1 on "Duck" you mean. Don't make me have to correct you again. lol
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
posted December 08, 2009 08:26 AM
Check the P/C ground please before you do anything else .. I grounded mine to the case cover bolt just below the coolant tank .. You don't have to add to the wire for that location ...Easy fix . . About the other problem give me a call .. I'll PM you my number ..
0.23171615600586 seconds processing time
