BIKELAND > FORUMS > ZX-14.com > Thread: How much HP can I find with IGNITION Modul ? NEW TOPIC NEW POLL POST REPLY
Axel from Germany
posted September 14, 2009 11:37 AM
Hello@ all,
how much HP can I find with IGNITION Modul ?
My configuration is :
Akra 4 in 1 System with Muffer, BMC, Powercommander V, Autotune, Speedohealder.
Sticks_n_Stones
posted September 14, 2009 01:57 PM
you referring to an ignition advancer? thats a toss up: more advance helps in lower gears/rpms (better 60' drag racing times) but in the higher gears// higher rpms after the launch its been proven to lose mph in a 1/4 mile race. IMO stock is best.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
gilberjj
Friend of Fast
posted September 14, 2009 02:32 PM
I think he's actually referring to the ignition module.....
http://www.powercommander.com/powercommander_iii_usb/powercommander_ignition_module.aspx
johnbull
posted September 15, 2009 03:41 PM
The ignition module is obviously a much better option than the advance plate because with the ignition module you advance or retard where and when you like by creating a graph on the software.
Like this you can for example advance your ignition timing in the mid range and leave the top end stock or even retard it a bit.
Advancing the ignition will probably not actually improve your bhp but it will definately improve your bottom end and mid range torque figures. It will also give better throttle response.
On good pump fuel I wouldnt go for more than 2 or 3 degrees advance.
John Bul Racing. Malta.
posted September 16, 2009 10:07 AM
i have been thinking of the msd ignition, although i would not adjust the timing much, i do believe a hotter spark would help some...
gilberjj
Friend of Fast
posted June 16, 2010 05:13 PM
BUMP:
I just picked up a dynojet ignition module. The main reason I got it was because I want some timing control when I put the turbo kit on my bike. However, are there any benefits of this ignition module now while I'm na? Does anyone have a map they want to send me? I don't remember Brock ever using an ignition module........
Sticks_n_Stones
posted June 16, 2010 10:58 PM
It's called "Bling" gilberjj: polish it and enjoy.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
gilberjj
Friend of Fast
posted June 17, 2010 11:27 AM
Halvefast
posted June 17, 2010 01:07 PM
once you install the ign module, if you look Brock has some ign mapping
already done in some of his maps. Biggest thing you will need is to pull timing
under boost which the module wont know. An EFIR from schnitz with a
pressure switch would work best. Problem is they dont have them anymore
have to find one used.
ECTA Ohio Mile 195.132mph
Quick Reply:
0.199320077896 seconds processing time
