BIKELAND > FORUMS > ZX-14.com > Thread: slip ons NEW TOPIC NEW POLL POST REPLY
ktb
posted August 27, 2009 06:37 PM
slip ons
I have a stock ZX-14 '09 would like to put Yoshimura slip-ons. Can I use the factory map? If you do not know about the topic, please do not give advice.
Thanks,
rich s
posted August 27, 2009 06:41 PM
I put on Brocks Slip-ons and had no problems. I just pulled the flies now and added a PC and before that it ran extremely smooth.
posted August 27, 2009 07:00 PM        Edited By: Shane661 on 28 Aug 2009 03:14
No remap needed.
ktb
posted August 27, 2009 09:32 PM
Thanks for the info.
3000psi and falling
posted August 28, 2009 08:26 AM
If you getting the r-77 slip ons, dont use swing arm spools, mine smashed the bottom of the cans. Also on mine the left mid pipe will hit the ground well before max lean.
Douglas Home
posted August 28, 2009 09:17 AM
I had the same spool problem , I removed the slider leaving the stand spool, then got a countersunk sockethead bolt and countersunk recesed the stand spool so it was flush.
I have a Yoshi TRC 4 into one carbon , it now has about10MM clearance.
Doug Mackay Australia
0.24205613136292 seconds processing time
