BIKELAND > FORUMS > ZX-14.com > Thread: speed restrictor nut NEW TOPIC NEW POLL POST REPLY
freddie900
zx 14 2007
posted August 10, 2009 11:24 AM
should i grind down 2 corners opposite of each other. has anyone done this and what kind of results did you get.
posted August 10, 2009 11:31 AM
only 1 corner needed from what I have read
Wheelie
Old Man
posted August 10, 2009 11:33 AM
my 16-48 gearing, I ground two sides. they were next to each other
wee
posted August 10, 2009 11:34 AM
jdrill04
posted August 10, 2009 11:35 AM
if you do two corners opposite of each other it will show half the speed. 140 will show 70. most people are just doing one corner. I did 2 corners opposite of each other.
wrongway
posted August 10, 2009 12:26 PM
I did 2 opposite each other, with a 17/43 gearing , the KPH is really close.
Roy
derpie
Dont judge a book by its cover
posted August 10, 2009 12:41 PM
Picture's of this would be swell as well as what a stock geared bike would achieve with this mod.
derpie
posted August 12, 2009 01:34 PM
bump .......
FastestBusaAround
I eat Fish...
posted August 12, 2009 02:32 PM
What is the speed restrictor nut, where is it and why do I want to fuck with it?
FYYFF!!!
freddie900
zx 14 2007
posted August 12, 2009 02:46 PM
to make you faster than 186 m.p.h.
14nooby
posted August 12, 2009 02:53 PM
The speed restrictor nut is you......................The nut restricting the throttle........heheheehe
freddie900
zx 14 2007
posted August 12, 2009 02:56 PM
which would produce higher top end speed 18/41,17/41 ,16/41 or 17/42 sprocket set-up on a stock bike?
posted August 12, 2009 03:24 PM        Edited By: Shane661 on 12 Aug 2009 23:24
With a stock bike, 17/42 should give you about all the top end you can muster (even with a bit of a tailwind). 16/41 would be a good choice also, allowing you to run more than 186 mph. In either case, rider aero's and the lackluster hp at high rpm (when bone stock) are going to limit you.
freddie900
zx 14 2007
posted August 12, 2009 03:29 PM
what will the top end be with 17/42 ?
posted August 12, 2009 04:00 PM
I don't know man...I don't have a bone stock bike. But the gearing will allow somewhere around 196 mph...the rest is up to your engine, and you.
derpie
posted August 12, 2009 04:13 PM
all good info , but back to my previous question ? where is this nut and how fast will a stock bike go? with this mod also what is the stock gearing 17/42?
ninjaboy311
posted August 12, 2009 04:27 PM
Its part of the front sprocket nut, take off the front sprocket cover and you'll see it, it has 4 corners on it.
derpie
posted August 12, 2009 04:47 PM
Ahhhh thanks
ninjaboy311
posted August 12, 2009 04:52 PM
I shaved mine with it still on the bike with a small dremel. The shavings will magnetize to everything, but I cleaned it all up after with no problems.
Rideharder
posted August 13, 2009 12:42 AM
Intrigued.. Any photos of this nut? Maybe I should take back my yellow box..
What's the benefit and what does it look like once it shaved?
Come to think about it I didn't really think my nut was bushy enough to be shaped..
I crack myself up... But for real I am interested in this.
  Ignore this member    Click here to visit Rideharder's homepage.
ninjaboy311
posted August 13, 2009 12:54 AM
Halvefast posted this on another site.....
Here is what you need to do to by-pass the 186mph limiter.
(Dis-claimer, this will lower you speedometer by 25%)
However we all know these read high already, so what's the harm.
Especially if you gear it down any, it reads much higher, so this will help bring it back in line anyway.
I noticed with this mod, and 16-43 gearing my speedo was spot on!
1) remove the contershaft sprocket cover, (5) 6mm bolts with 8mm heads
(DO NOT touch clutch lever while cover is removed,
this will push slave cylinder out and create headaches you don't need)
2) bend tabs back flat on sprocket nut lock, remove countershaft sprocket nut.
(Some are a real b#tch, others not so bad)
3) There are 4 corners on the outermost end of the nut, not the 6 sided part to remove it.
Grind down one of the corners similar to the one pictured. (See pic below)
You need to make a smooth radius close to same width as where the corner doesn't exist.
4) Re-install when finished, make sure to bend tabs back down on lock,
and careful not to pinch any wires with sprocket cover.
Check clutch operation is normal afterwards, before test ride.
Before you speedo should read 80mph @ 4,000rpm in 6th gear
afterwards speedo should read 60mph @ 4,000rpm in 6th gear!
So at what would have been 200mph on the speedo is now 150mph
I believe a replacement nut is only around $12-15 bucks if you don't like it.
Douglas Home
posted August 13, 2009 02:28 AM
I thought a "speed restrictor nut " was the policeman who took my liscence off me!!
2 months and 17 days to go .
Doug Mackay Australia
freddie900
zx 14 2007
posted August 13, 2009 10:28 AM
173 mph is the fastest i'v done soo far with the gps on my bike. speedo was reading 192-193 mph. i'm going to grind down the corner or 2 corners on my resrictor nut and see what the gps reads.
posted August 13, 2009 10:39 AM
I'll pass on all that... I don't go over 150 in the 1/4 and there's nowhere to do top end around here
freddie900
zx 14 2007
posted August 13, 2009 10:44 AM
it's a 1-3/4 mile straight next to our airport.
0.23212099075317 seconds processing time
