BIKELAND > FORUMS > ZX-14.com > Thread: Low Fuel Light ohm measurements NEW TOPIC NEW POLL POST REPLY
Compton
posted July 26, 2009 11:16 AM        Edited By: Compton on 26 Jul 2009 19:16
I've been slacking on this enough!! and found a low fuel light setup in my tool box.
note i used water, i don't know if gas makes a difference!?
that is out of the water, using the housing as the ground, like the oem pump would and the wire as the other source.
now i drunked it in the water and left the other wire out of the water and let it sit for 30 seconds and it showed this.
I don't think that is enough of a change to really trigger it, but could be. any thoughts or another way i should test this. i remember doing this before, but i dont remember what i did. whoops, too many gas fumes!
b.w.
posted July 26, 2009 11:30 AM
I am not sure Brian.
I will have to check my wiring schematics again too.
I though it would have been as simple as plugging the level sending unit wires and good to go, but you actually were the one, as well as Will, to bring up this issue.
Compton
posted July 26, 2009 11:35 AM
I thought Will said he just grounded the wire, and it still flashes on the dash.
Unless you would have the ground that wire(s) to the chassis?
b.w.
Mark524
posted July 26, 2009 06:49 PM
I'm assuming you are trying to go with an external fuel pump?
When I installed the Muzzy fuel system, I put a 1000 ohm resistor inline, you won't ever get the low fuel warning. The resistor I used actually comes up 1144 on my meter, but it's a cheap meter and there variation from one resistor to the next. Hopefully this helps
bigwil
06 zx 14 turbo stage 3
posted July 27, 2009 06:39 AM
mark
when you say you put the resister inline ,inline to what
cuz the other two wires go to the new fuel pump pos/neg
and the third low volt wire goes no where now
did you put just the resister on the end or did you ground it
bigwil// going fast aint easy so turbo it
posted July 27, 2009 07:36 AM
+1
anticipating helpful info here.
Much appreciated too!
Mark524
posted July 27, 2009 01:29 PM
I'm actually in the process of going back to the stock pump. I'll go see how I wired it. It's been a long time since I figured it out.
Are you guys using the Muzzy system? Just curious as when I had the same problem, their tech guy told me that nothing was required to make the fuel sensor work. Wrong. I had to figure it out on my own.
Compton
posted July 27, 2009 01:35 PM
I'd assume its low light to ground with a resistor between those two.
b.w.
Mark524
posted July 27, 2009 01:40 PM
you're basically replacing the signal of the sensor in the tank with a constant approx 1000 ohms. If memory serves me the sensor is grounded on one end and the other goes up the harness to the ecu? It will come back to me when I get eyes on it later.
Compton
posted July 27, 2009 02:19 PM
the sensor is grounded on the pump, which gets grounded to the housing on the bottom with the nut.
Big Will has the muzzy setup, believe dubious has his own setup. im still running a stock fuel pump setup, i'm just trying to help!
b.w.
posted July 27, 2009 10:41 PM
I am running a massive wedco pump, but need to fool the ecu same as you muzzy guys, or anyone running a aftermarket pump, I think.
Thanks guys!
bigwil
posted August 05, 2009 06:16 PM
just whanted to say thanks
installed a 1k ohms 1 watt resister then grounded it no more flashing
Mark524
posted August 06, 2009 01:26 PM
bigwil, glad you got it figured out. it sucks that we have to figure it out on our own and it's not addressed in the kit when you pay $700 or whatever it costs.
I bought mine when they first started selling it, and I'm not good with wiring and it took me all the same experimenting like compton did to figure it out.
posted August 06, 2009 01:31 PM
thanks for sharing.
I will be getting back at the bike in the next few days when i get home.
Compton
posted August 06, 2009 03:24 PM
team work! lol
what should we tackle next?
b.w.
posted August 06, 2009 04:36 PM
I have alot of electrical hurdles to overcome right away.
The most difficult will be shortening the harness, and relocating the ecu where the left ram air tube used to be.
If Will could go over his ams 1000 wire connections, indicating which wire on the stock harness/ ecu was connected to which wire on the ams1000 harness, that would be awesome!
I will be wiring and relocating the MSDSB6, microtech, innovate, speedohealer, PC5 with boost based map, and independant control of fuel trim for each cylinder.
Since my harness will be shortened and relocated, it will be a bit more difficult than it sounds!
I will also be looking to make a new dash with ability to mount 4 gauges, shift light and few other accessories.
If possible it will replace the stock ram air tube covers, and mount around the stock guages as well.
If it turns out well, I will likely make a few duplicates for those interested.
Mark524
posted August 07, 2009 12:51 PM
I can't imagine the wiring nightmare with the turbo and all those electronics. My bike is completely back to stock now, ready to sell. The stocker is simple compared to what I had. I never thought I would say that
posted August 07, 2009 03:22 PM
I know,
Yeah, I have been avoiding it......
0.22918105125427 seconds processing time
