JDC
posted March 23, 2009 05:07 PM
Edited By: JDC on 24 Mar 2009 01:07
Turbo spark plug gap and changing time
What gap are you turbo folks running your plugs at and
how long would you say it takes, average, to pull them and throw them back in?
gracias...
posted March 23, 2009 05:47 PM
15 minutes, use factory tool in tool kit
.20 gap
CR10EK... one colder than stock with dual electrodes....Same as Bob...
BTW
I stand corrected, Bob has been pulling 6 degree's time, at 5 or more PSI
Thought you might be interested.
posted March 23, 2009 06:43 PM
Edited By: dubious on 24 Mar 2009 04:13
I meant dual ground straps ... one electrode...
I ran them in my bike with the 50 shot on pump and never had to pull timing... although I think the shitty winter fuel ( october) almost got me the last time I had it out...
It began to detonate, so i shut it off.
When I pulled the plugs they has very miniscule aluminum specs...
Everything looked good when I pulled the motor apart for turbo build... it must have just gotten on the ragged edge.
winter spring and fall, ya gotta be real careful cause they dilute the shit out of the fuel with butane which lowers the octane and flash pt of the fuel drastically.
JDC
posted March 23, 2009 10:40 PM
dubious,
thanks...
" I meant dual ground straps ... ?"
posted March 24, 2009 06:55 AM
I gotta take a buch of pics today, I put one up of the plugs
JDC
posted March 24, 2009 05:28 PM
Thanks dubious.
Someone initialy told me 2 hours to take plugs out....
musta been smoking.
posted March 24, 2009 08:03 PM
Use a allen socket in cordless drill for plastic hardware....
Unplug all the coils, pull the air injection harness out of the way,.... mine is long gone
Use the stock spark plug socket.... put electrical grease in boots, spray wd 40 in spark plug wells after new plugs are in, so coils slip in nice
posted March 25, 2009 07:29 AM
I forgot its way easier with Air injection block off plates....
Plugs:
JDC
posted March 25, 2009 07:51 AM
dubious,
thank you!
posted March 25, 2009 08:24 AM
camera was dead last night.... sorry for delay
posted March 25, 2009 08:29 AM
Edited By: dubious on 25 Mar 2009 16:32
Oh , and contrary to the manual, especially on rich tuned turbo or Nitrous maps, I found an appreciable increase on power, throttle response, and smoother idle after changing plugs at 6000 miles.
High combustion pressures / temps are hard on plugs
I think a while ago smokin lee had also posted about the nice change in power after changing his too.
You won't notice them going away cause its so gradual, but if you let them go , you will notice a change when they are replaced.
JDC
posted March 25, 2009 08:55 AM
great info, Dubious
much appreciated... plugs are on tyeir way to a new home
JDC
posted March 28, 2009 09:28 AM
Mine are OEm .030'. Bike seems to run great as far as I can tell.
Do you think re-gapping to 035 or 020 really makes a difference in how the turbo setup will 'feel'?
and
ZXBob, you have an ATP setup, what gap are you using, please?
posted March 28, 2009 02:35 PM
Tightening the gap will help prevent flame out, it won't hurt anything, but is added insurance to prevent hurting anything.
I would definately not widen the gap!
1badzx12r
posted March 28, 2009 03:15 PM
Edited By: 1badzx12r on 28 Mar 2009 23:15
quote: Mine are OEm .030'. Bike seems to run great as far as I can tell.
and
mine ran best with the iridium OEM plugs also ..but i was told you can blow the flame out on those plugs ..
JDC
posted March 28, 2009 03:27 PM
got it.
I had never heard of that before.
gilberjj
Friend of Fast
posted October 26, 2010 10:08 AM
I just ordered these plugs. My turbo will be on e85, should I have ordered the stock plug because e85 burns so cold?
01smokes
posted October 26, 2010 10:26 AM
quote: I just ordered these plugs. My turbo will be on e85, should I have ordered the stock plug because e85 burns so cold?
I ran stock plugs on my bike the ones that came from factory I never checked the gap on em but I think I'm going to a one step hotter plug on this motor. E85 is hard to light and the bike ran so damn cold.
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
gilberjj
Friend of Fast
posted October 26, 2010 10:43 AM
Interesting...... anybody else?
01smokes
posted October 26, 2010 11:24 AM
As far as I know I'm the only one that has ran e85 And boost on a 14 a few booza guys are starting to switch now
oldkawboy
posted October 26, 2010 01:45 PM
I run one range colder and have them gapped at .022" on my turbo ZRX. I had problems at .035", don't know if it was flame blow-out or not but it runs better with the gap closed.
Dan
