BIKELAND > FORUMS > ZX-14.com > Thread: muzzys lowering links NEW TOPIC NEW POLL POST REPLY
zerotahero
posted November 26, 2008 05:35 PM
anyone know anything about these? i have them on my 14 my ? is there is three hole settings which one puts the bike the lowest. thanks
bawls
re-learning to ride
posted November 26, 2008 05:44 PM
I'm pretty sure it is the bottom hole... but it's been a while since I installed mine. The longer the link... the higher the rear tire is pushed up into the fender, but you can't ride it on the street like that. You really have to watch it on the middle hole, because if you wheelie and come down hard you run the risk of smashing your oil pan. and it will scrape speed bumps. Evidently I came down pretty hard last time I was at the track, because I've got a nice ground down spot on my tab and oil plug.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
kawabunga
Cogswell Cogs Installed
posted November 26, 2008 06:06 PM
If you set them in the lowest setting you will need the Muzzy shock travel limiter to keep from bottoming on the swingarm with the fuel pump.
bawls
re-learning to ride
posted November 26, 2008 06:34 PM
And your bike will ride like a log truck.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Silver08
posted November 26, 2008 07:22 PM
if you have an 08 or 09, the fuel pump will not hit
08 ZX14
posted November 27, 2008 06:42 AM
mine is all the way down and yes it sucks horribly riding on the street...
bawls
re-learning to ride
posted November 27, 2008 09:05 PM
I'm 175 lbs and run mine on the second hole in the rear and 1" in the front. I have scraped a couple of times but other than the one at the dragstrip, I haven't had any problems out of mine. It looks good, and my best 60ft is a 1.56 with just the bones and a strap.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
flatoutbu
posted November 28, 2008 05:41 PM
I have a straight link on my bike and it solves all those problems. You can run the spring at a comfortable tension and not have any bottoming out problems. You can use stock dog bones with a straight link and get really close to a perfectly flat swing arm level. I have seen a 1.39 60's on bike at 65 1/2 inchs.
06 Blue 14
9.008 at 153mph @ 195 suited
Copyright 2000-2023 Bikeland Media
0.37416291236877 seconds processing time
