BIKEGOD
I'm lost???
posted October 06, 2008 04:25 AM
wiring diagram.
So..................................On Friday night, I change my subframe *amongs other things*
Upon putting the new one in I pinched some wires, I didnt even realize.
Till we were on the dyno about to get some HP down. When I noticed smoke coming from under the gas tank. Naturally I quickly shut the bike off.
I took the tank off, and realized I had pinched the harness coming from the stator *after the connector* against a ground bolt on the subframe.
Needless to say. I ordered a repair manual from ebay for 70.00 *the dirty dealer wanted 108.00*.
However, until the book arrives. How and where can I look at a wiring diagram of the bike, so that I can see the values. for said wires.
I need to decifer if the resistor is good/stator/wiring etc.....
I'm a friend of your mom's,
Get in the car !
BIKEGOD
I'm lost???
posted October 06, 2008 02:48 PM
c'mon.................some one must know......................woppi????
Get in the car !
AZ ZX14
posted October 06, 2008 05:13 PM
I can help you. PM me your email address.
2008 ZX-14
Flies out
PCIII / USB
Brocks Alien head
Puig DB Screen
MJ
posted October 07, 2008 12:38 AM
quote: So..................................On Friday night, I change my subframe *amongs other things*
You shoulda came here before you ordered the service manual, we coulda got you one for free. Sounds like you may still get a backup for your paper one anyways
BIKEGOD
I'm lost???
posted October 07, 2008 03:29 AM
oh, okee dokee. hey man, I'll even print it off * at work, of course*
Ive sent my email. Thanks AZ.
Get in the car !
AZ ZX14
posted October 07, 2008 05:09 AM
Its on the way. Good luck!
2008 ZX-14
Flies out
PCIII / USB
Brocks Alien head
Puig DB Screen
BIKEGOD
I'm lost???
posted October 07, 2008 07:00 AM
Got it thanks man,
Now I can get started asap.
Get in the car !
Highlander0565
posted July 19, 2012 10:39 AM
I recently purchased an alarm system from Scorpion Alarms (rlink1100SE) and it requires that I tap into existing wiring for the lights. Where can I find the wiring diagram for the 2010 ZX 14, so I do not mistakenly tap into the wrong wire?
Seno
BANNED FOR LIFE!
posted July 19, 2012 11:29 AM
quote: I recently purchased an alarm system from Scorpion Alarms (rlink1100SE) and it requires that I tap into existing wiring for the lights. Where can I find the wiring diagram for the 2010 ZX 14, so I do not mistakenly tap into the wrong wire?
You do not need to tap into the lights, there is a connector kit. I have the same alarm but even with the connector kit it was REALLY tight to the point I spliced the connector kit and added 3-4 inches.
Regarding the manual, here is the link
http://www.zx14ninjaforum.com/PDFs/2012-ZX14-Service-Manual.pdf
Seno
BANNED FOR LIFE!
posted July 19, 2012 11:31 AM
Once it downloads (you will need Adobe PDF reader), click File, Save as and chose a location... What I do is print out the pages that apply to what I am working on... If they get dirty or whatever I just throw them away & print out new ones if needed...
Highlander0565
posted July 19, 2012 02:11 PM
What area or location does the connection kit connect to? Is there a harness assembly that connects to avoid the wire tapping>
Seno
BANNED FOR LIFE!
posted July 19, 2012 02:41 PM
The connector kit basically connects the rear lights to the alarm, its plug & play. The front lights go through the factory harness that has the correct plug or relay under the seat. Installation takes about 30-45 minutes, unless you are a permanent student on the short bus
Highlander0565
posted July 19, 2012 05:38 PM
Thanks, I realize my mistake was not ordering the factory kit. I just ordered it and hopefully it will keep me off the short bus....
