zx14c5
posted September 26, 2008 03:54 PM
Sprocket Install
I am preparing to change my countershaft sprocket this weekend to the OEM 16T, and am putting together all the required tools, etc. According to the manual i need to apply a molybdenum disulfide oil solution to the engine sprocket nut when installing the new sprocket. The closest thing I could find locally is called "Coastal Premium Moly EP Grease" which comes in a silver tub. The label says it contains molybdenum disulfide, but no percentages, or list of other ingredients. Does anyone know if this grease is suitable for this purpose? My guess is it should be fine, but wanted to check.
smokinzx14
posted September 26, 2008 04:00 PM
Edited By: smokinzx14 on 27 Sep 2008 00:01
That should work just fine ... ARP Makes a moly lube that you that you are looking for , you can get it at any Hot Rod store ...I don't use anything on mine and never had a problem ...
Hurricane
posted September 26, 2008 04:25 PM
Don't forget your speedometer will be about 11.5% off. You need to get a speedoHealer!
street racer
posted September 26, 2008 04:56 PM
I didnt use anything on my nut either. Sure was glad I had an impact driver though as that nut is on tight from the factory.
zx14c5
posted September 28, 2008 06:30 AM
Thanks for the replies. Yep, I installed my Speedohealer v4 last week while I was waiting for the countershaft sprocket to arrive. I'm also installing a Driven Steel 43T rear at the same time.
street racer
posted September 28, 2008 06:40 AM
Gitter done ??
russ8526
posted September 29, 2008 08:17 AM
driven steel 43t where can i pick up one?
2007 zx-14 Limited
Brocks Alien Head
BMC Race Filter
PClll w / Track Map
Flies Removed
16 T Front Sprocket
Speedohealer
Fender Eliminator
