BIKELAND > FORUMS > ZX-14.com > Thread: 16T Sprocket....Issues? NEW TOPIC NEW POLL POST REPLY
shane661
posted August 22, 2008 05:00 PM
I'm getting ready to install the 16T countershaft sprocket this weekend. But I've seen some people apparently have "issues" with chain slap, or similar. Is this a guaranteed problem with the 16T? If so, I have plenty of room to go up on the back...just looking for some input, particularly from those who drag race.
Smooth_G
posted August 22, 2008 05:38 PM
i have been using a 16t for 3000 miles,, no problem,,,it does whurr because it doesnt have the vulcanized rubber on it,,
ninjaboy311
posted August 22, 2008 06:17 PM
Over 600 drag strip passes with 16T with no issues.
smokinzx14
posted August 22, 2008 06:42 PM
Ditto ...............
oldkawboy
posted August 22, 2008 06:54 PM
I put an OEM 16t with the rubber damper on mine Shane and it works great.
Dan
zx14mike
posted August 22, 2008 07:06 PM
Never had any issues with mine...............I know Lietoome went back to the 17 tooth after he stretched it and i think it was because of chain slap.......but not positive..........i know he also wanted max wheelbase and wanted to use the dampened sprocket.
zx14mike
posted August 22, 2008 07:07 PM
I think you'll like the 16 tooth Shane..........if not just go with 17/45 or 17/46 instead.
Hurricane
posted August 22, 2008 07:13 PM
My 16T does make a noticeable whurr. I am thinking of putting the 17T back because the rubberized damper does makes a big difference in noise. I will then put a bigger rear sprocket 17-44. I think you should do the same...
shane661
posted August 22, 2008 07:14 PM        Edited By: shane661 on 22 Aug 2008 20:15
Dan
Which bike is that from, Dan?
Hurricane
posted August 22, 2008 09:22 PM
Dan, I have not heard of a 16T OEM or aftermarket sprocket with the rubberized damper for the ZX-14. Here did you buy that?
lietoome
posted August 22, 2008 09:25 PM
I like the 17/45 combo. For me, the 16t felt like it spun up way too fast. It did make some noise, so I also went back to the dampened sprocket. The gearing is relatively the same, I just like the bigger rear sprocket. My 16t rubbed on my Velocity Arm, but not on the stock swingarm.
Cajunboyz
posted August 23, 2008 04:13 AM
Dan
Which bike did the OEM 16T with rubber dampner come off of???
Was the part#13144-1317 ???? Enquiring minds want to know??
posted August 23, 2008 05:29 AM
The origional post for the OEM 16 tooth front sprocket...
http://www.bikeland.org/board/viewthread.php?FID=27&TID=27460
oldkawboy
posted August 23, 2008 05:40 AM
Bingo.........
As usual Rick is correct!
The sprocket from the '92-'94 Zephyr (ZR1100) is the one. Part # 13144-1317.
Dan
posted August 23, 2008 06:32 AM
If it wasn't for Zack, I wouldn't have been able to post this info...
Which means that I really need to thank you Dan for getting me in touch with Zack !!!
shane661
posted August 23, 2008 08:24 AM        Edited By: shane661 on 23 Aug 2008 09:26
Bingo.........
Dan
Off topic, but the Zephyr would have had a much bigger following with a better name. What was the logic, "Let's build a bike that evokes the memory of the fearsome Z1...and call it.......the Zephyr."?
0.29707908630371 seconds processing time
