BIKELAND > FORUMS > ZX-14.com > Thread: stripped my butterfly bolts NEW TOPIC NEW POLL POST REPLY
specialzx14
posted February 24, 2008 12:29 AM
hey i just took my butterflys out and i stripped two of the bolts whats the easiest thing i can do to get them out. should i try to drill them out or what.
specialzx14
posted February 24, 2008 01:23 AM
nevermind i got them had to do it the old redneck way with a hammer and flathead
BlackMagic14
posted February 24, 2008 01:42 AM
I have had to use that one a couple of times!! Taking the flies out is one of those funny things it doesnt really get easier the more you do it! I have taken several out and the easiest one I ever did was mine (the first) it seems to get harder everytime
bigwillie3236
posted February 24, 2008 03:20 AM
Qwick, told me to get a Kliens screwdriver ,hardened tip 11 inches long and man it was a piece of cake .
reynoldss
posted February 24, 2008 09:11 AM
Mileage could play a part in the difficulty of removing them.
Everybodys tyring to go green, I did years ago.
posted February 24, 2008 09:40 AM
the thread locker they use is more like an epoxy, a heat gun does wonders too
thutch26
thutch26
use a good soldering iron and heat them up real well.... loosens up the threadlock....... piece of cake !!!!!
kaw now
posted February 24, 2008 02:26 PM
There is one trick no one mentions. With left cover off turn on ignition and butterflys cycle full open then close. Watch the moving part and grab that while loosening the screws to keep the butterfly shaft from rotating while loosening. I heated the screws with a solder iron and to remove the screws push down on screw fairly hard while applying turning pressure. The key is not to let up on the downward pressure or the driver will cam out and strip the screw. Keep a steady turning pressure and the screw will start to turn, don't expect it to turn right away. If the driver cams out and damages the screw try some valve grinding compound on the driver tip and use a new screw driver before anything like drilling out. I have also used a dremel type tool to cut a slotted head on a buggered screw before, turning a philips screw into a slotted but not sure of the clearance in this application.
phil
posted February 26, 2008 06:21 AM
+1, A little bit of that stuff can work wonders.
"Look at Dad, trying to look young again."
qwick
posted February 26, 2008 10:04 AM
Go to Lowes BEFORE attempting to pull the flies... buy a Klein "Electricians" #2 11" long screwdriver with the hardened tip. The Klein brand is located by themselves, away from the other tools. Cost was just under $8, but well worth the money!!! We did two 14's, back to back...first the 08 and then my 06. NO PROBLEMS whatsoever!!! We heated the first two screws, but found no difference removing them without the heat. Just make sure to apply firm pressure while trying to keep the screwdriver perfectly straight (a few of the screws are a little hard to get directly overtop of) and only attempt to make a 1/4 turn at a time, this is important... and remember to stop turning before you let up on the pressure to the screw head, they are VERY tiny... then REGRIP & repeat. Do Not get in a hurry, I believe that's where some get into trouble. Just imagine that you're disassembling a Bomb... that mind-set worked Very Well for me.
Hope this info didn't offend the mechanics onboard, it was intended for those (like myself) who want to do this mod themselves, but are a little unsure of what they may be getting into, especially with all the stripped screw reports that have been posted in the past.
blackbullet76
posted February 26, 2008 10:50 AM
A brand new long #2 screwdriver is the best way to go. I bought one and used it on my 07 and it hasn't been used since. It took them loose, no problem
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
LawyerA
posted February 26, 2008 01:12 PM
If you have already stripped some screw slots where no type of screwdriver is going to help, I recomend the purchase and use of a decent set of needle nose channel lock pliers. You will need a set with the jaws being squared off so that when you grasp the screws, the jaws will be flush on the secondary plates. Also while holding the linkage so that the flies will not open, press down on the pliers while turning slowly but surely counter-clockwise. All this should be done after the bike is warmed up a little, and the screws directly heated if possible. I recommend trying this several times before resorting to drilling the screws out. And yes, I found all of this out the same way as you. Put a magnetic probe or at least a rag underneath the secondaries and above the primary flies. Most of the time at least one screw will drop down, and hopefully get caught by the primary flies. Good luck!
hardcoremass
Powerhouse
posted March 04, 2008 04:11 PM
Use extreme caution when using a flat head and mallett, the servo shaft can be bent very easily. Try grinding approx 1/16" off tip of phillips, use file to reshape blades, and with slow, even pressure loosen screw. Remember to have patience!
07 zx14 (black), flies removed, BMC race filter, Muzzys M10, PClll, PC ignition module, RT ext, Muzzy lowering links, 40 shot spray
BIG BLUE_ZX14
posted June 14, 2008 01:40 PM
Quick and hardcoremass are right, be slow and deliberate and removing the flies will be no problem. My 14 had approx 1500 miles on it when i removed the flies. Using a brand new screwdriver I applied firm pressure and slowly turned each screw. They came right out no need to heat the screws (although i had a heating iron on stand by). I was paranoid about loosing a screw down the throttle body so once the screw was loose i put a megnetic pick up tool down next to it. That first ride with no flies was swweeet!
2007 Blue ZX14 Gone...
big mike_zx14
posted June 14, 2008 03:47 PM
I went the Klein and soldering iron route, worked awesome....
2005 ZX12R...(sold)
Akrapovic Full Race System, PC3, BMC Race Filters, Puig Windscreen, Helibars, Pro Grips, Clear Alternatives LED Integrated Tailight, Gilles Rearsets, Extreme Graphics Hugger, Engine Ice, Dino Hinge...
2007 ZX14....
Brocks Gen 3 w/carbon can, PC III, BMC Race Filter, Amsoil, Engine Ice, ShoGun parking lot sliders, Puig DB windscreen, Heli Bar risers, Pro Grip gel's, Competition Werks fender eliminator, Vortex rear sets, No flies...More to come of course..
posted June 15, 2008 08:09 AM
start up the bike and get it warm first then remove the butterflies
Smooth_G
posted June 15, 2008 09:19 AM
i warm the engine up to get the whole shaft hot,then appied a soldering gun to the top of the screw that i am working on, then make sure the screwdriver is straight in the screw n perpendicular,,used a number 2 klien screwdriver,worked perfect,,i could reuse the screws
ninja14
posted June 15, 2008 10:49 PM
A hammer is the WORSE thing............
....if you bent that shaft a little - screwed......I know of a couple that have done it.....
2006 Turbo ZX-14.
2005 V-max 20th Anniv.
mike1024
posted June 16, 2008 06:39 PM
haha youre stupid OFFICIALLY. good job moron
Superman T
posted June 17, 2008 07:05 AM
This was the BEST advice by far. I got mine out with zero problems. Thanks Qwick!
kawasaki_1965
Bone Stocker
posted June 17, 2008 12:31 PM
Removed flies from 14s and the Connie14, never a problem. I know the tip doesnt help matters at this point but it's a piece of cake if you remove them after really warming the motor up to the point the fan comes on then spray some SeaFoam and let it soak for 3-5 minutes. Lightly tap with the right screwdrive and wala!..they are off without a hiccup.
ninja14
posted June 17, 2008 10:20 PM
.... Lightly tap with the right screwdrive and wala!..they are off without a hiccup.
wala? ............your version of French
The screws are a funky Japanes size.......but they can't beat us
2006 Turbo ZX-14.
kawabonzai
Leader of the Back.
posted October 22, 2008 11:46 PM
Add me to the list of idjits who just stripped a screw. Done several bikes and this is the first one stripped.
I'm tempted to reach for the hammer ... hehe lol. No!
MY brand new Klein #2 aint helping either, it's a cereal bowl in the head now.
2009 ZX-14 Candy Lime Green
MasterBlaster
posted October 23, 2008 07:22 AM
I used a set of extra long 90 deg needle nose pliers that I ground the jaws back halfway so the jaws are shorter and more beefy. Do 1/4 turn at a time and they will come right out. On both my ZX and C14 one or two was very stubborn. The extra long handles give you a great mechanical advantage to grip the head of the screws with, and the length of reach you need to access the screw heads.
KawaBonzai
Leader of the Back.
posted October 23, 2008 09:19 AM
You mean something like these ...
0.22572803497314 seconds processing time
