BIKELAND > FORUMS > ZX-14.com > Thread: water wetter NEW TOPIC NEW POLL POST REPLY
blackbullet76
posted July 09, 2007 09:52 AM
water wetter
Just bought me a bottle of this stuff, but I don't know how much I'm supposed to pour in. Any idea? Also, do I need to drain any coolant out before I add it or will it be ok to just pour some in?
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
LandspeedLarry
posted July 09, 2007 11:06 AM
The 14 has a 3.6 qt. cooling system. Water Wetter suggests one ounce per quart so that would be 3.6 oz.. Pour 3.6oz into a cup and see what you think. You might have room to just add it. You could always pour it in the overflow tank and it would be siphoned into the engine when hot. Stay COOL!!
Home of the World's Fastest Naturally Aspirated motorcycles.
fastestbusaaround
I eat Fish...
posted July 09, 2007 03:56 PM        Edited By: fastestbusaaround on 9 Jul 2007 16:57
I used it like they recommended; not much diff, so I poured the whole bottle in; worked much better! Never runs over 1 bar above half now...not even in heavy 90+ degree stalled traffic. You need to drain all the coolant and just use distilled water for maximum cooling...otherwise you'll see zero effect.
FYYFF!!!
FasterThanStink
posted July 09, 2007 03:59 PM
Yup. Use only distilled water and drain some coolant out of the radiator. In my experiance adding to the overflow tank is hit or miss if it ends up in the radiator.
That's what gets you.
fastestbusaaround
I eat Fish...
posted July 09, 2007 04:59 PM        Edited By: fastestbusaaround on 9 Jul 2007 18:00
Agreed; I flushed the rad completely before I changed the mix. See my post in this thread.
http://www.bikeland.org/board/viewthread.php?FID=27&TID=32796&set_time=1184028960
FYYFF!!!
Xtremespeed
posted July 09, 2007 05:03 PM
I remember when I bought my ZX-12r. Everyone was pouring the whole bottle in. It's not what they recommend, but it worked well for me. One bottle, and the rest, distilled water.
BobC
posted July 10, 2007 03:21 AM
My bike's overheating problems went away when I fitted the Titaniun TiForce exhaust system but I'd still like to ask:
Modern coolants contain corrosion inhibitors, as well as being an anti-freeze. Is there any chance that using an alternative such as Water Wetter and distilled water could introduce long-term problems ? Has anyone tried simply removing the thermostat, or tried to find out if Kawasaki have alternative 'stats for different countries ?
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
blackbullet76
posted July 10, 2007 03:57 AM
Well if I used just water and the water wetter, when winter time rolls around, I would have to put antifreeze back in right?
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
ZXLNT
posted July 10, 2007 04:06 AM
Depends on how cold it gets there..
Xtremespeed
posted July 10, 2007 06:15 AM
I believe water wetter has the corrosion inhibitors, but not the anti-freeze properties. I have run it in street cars and motorcycles for years with no problems. It doesn't get very cold here though. One thing to remember is that ethlyene glycol increases cylinder head temps 1 degree for every 1 percent you use, so if you have a 50/50 water/glycol mix, you raise cylinder head temps approx 50 degrees.
When in doubt, Flick it!
BobC
posted July 10, 2007 06:55 AM
Now that's the kind of information we need, many thanks.
blackbullet76
posted July 10, 2007 07:18 AM
Thanks for the info.
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
Xtremespeed
posted July 10, 2007 12:06 PM
Glad I could help for a change. Lol!
intimida2or
RED rider!
posted July 10, 2007 03:05 PM
I too flushed , distilled watered , and used a full bottle of water wetter with great results
'06 Passion Red ZX-14
*Lee*
87gtNOS
posted July 11, 2007 10:45 AM
In everything I own I put a whole bottle of Redline Water Wetter.
My snowmobiles and bikes get each a whole bottle. My S/C'd Mustang gets two bottles!
As for corrosion, it's always a good idea to flush coolant every couple year anyways. Coolant can become acidic with time.
01 ZX12R
Ninja_Knight
posted July 11, 2007 12:42 PM
That is awesome info guys! Thanks!
zxbob
posted July 11, 2007 07:07 PM
+ 1
Dont need to worrie about freeze protection here in Cali ....
Bob
BBoy1255
posted July 12, 2007 08:21 AM
live in detroit michigan if i put a bottle of water wetter and distilled water i can still add some antifreeze. i guess what im tryin to say is can i mix all three and about how much antifreeze will i need to keep it from freezing
Xtremespeed
posted July 19, 2007 05:17 AM
You can mix all three. Hard to say how much to keep it from freezing though. It gets pretty cold up there. I would say maybe 1 qt glycol?
87gtNOS
posted July 19, 2007 05:20 AM
50-50 on the antifreeze and a whole bottle of Water Wetter into the cooling system first, then fill it up with 50-50.
01 ZX12R
posted July 19, 2007 08:27 AM
50-50 is good for approx -40 degrees; and even then it won't freeze it will gel.
blackbullet76
posted July 22, 2007 06:13 PM
Well, I just cyphered out some of the factory coolant and poured the whole bottle in, then added a little water to top it off. It definitely made a difference.
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
kevin_stevens
posted July 24, 2007 10:19 PM
Why are y'all just making this up as you go along? If you're pouring a whole bottle in, why not make it two, or three, or hell, fill the whole system up with the stuff?!?
Redline *tells* you how much to use - 1oz/quart. It's printed on the frikkin' bottle! For a 4 quart system, that means 4 oz. If you're putting in a quart, that means you're putting in TEN TIMES (because now you only have 3 quarts water, so the proper ratio would have been 3 oz) as much of the stuff as they recommend for best cooling performance!
Then you say "it works great!". Imagine how great it would work if you RTFM! Do you really think that if TEN TIMES as much WaterWetter was the right mix, that Redline wouldn't want to sell you that much?
Sheesh.
KeS
fastestbusaaround
I eat Fish...
posted July 24, 2007 11:21 PM
FYYFF!!!
blackbullet76
posted July 25, 2007 10:16 AM
Uh.............that dudes pissed!
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
0.27299809455872 seconds processing time
