BIKELAND > FORUMS > ZX-14.com > Thread: Yea oil pan fixed NEW TOPIC NEW POLL POST REPLY
serius blk
posted November 29, 2006 05:19 AM
Yea oil pan fixed
After knocking a hole in my oil pan. I was able to drill and tap a hole in the side of the pan. My welder welded the bottom flat. Looks like a skid plate. This was one of the best things i did. I dont have to worry about the plug hitting anymore. The pan came off easy also. If you have your bike lowered. This would be a good move. I only spent 50 bucks including the labor and the bit,tap and new plug.
kspz3
posted November 29, 2006 06:10 AM
Pictures please......
BobC
posted November 29, 2006 07:50 AM
I drop the suspension on my bike for the straight line stuff only and go back to standard height for the road. Not only safer that way but more ground clearance for cornering.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
KAWABUSAKID
Fast as my $$ will take me
posted November 29, 2006 01:52 PM
i did same thing,...i modified mine too,will post pics
  Ignore this member    Click here to visit KAWABUSAKID's homepage.
kawabusakid
posted November 30, 2006 03:57 PM
kawabusakid
posted November 30, 2006 03:58 PM
smiddy1
posted November 30, 2006 06:42 PM
Forget about the oil pan statement on the other thread, that,s nasty. Drains on the side stand, pm sent.
Get on the line and drop it!
The Nitrous Advice Forum
posted November 30, 2006 06:59 PM
serius and kawabusa
Did you shorten the pan or did you just close up the drain plug hole and move the drain to the side???
kawabusakid
posted November 30, 2006 07:18 PM
I had it shortened Very little and then moved it ,a friend of mine did it for $40,i just had to put the allen plug in and tape the hole.
posted December 01, 2006 09:08 AM
What about the oil screen and pick up???
Are you sure they are ok???...If not you could have a problem!!!
Check with Coby Adams http://www.adamsperformanceinc.com/
KAWABUSAKID
posted December 01, 2006 01:10 PM
yea,i checked clearance before i did it ,everything is good
0.2332010269165 seconds processing time
