BIKELAND > FORUMS > ZX-14.com > Thread: Dry NOS accessories NEW TOPIC NEW POLL POST REPLY
smiddy1
posted September 22, 2006 07:23 AM
Dry NOS accessories
Really they are a must for a safe system. I've seen what can happen they are not used when using NOS FOR FUN.
1- Window switch, DO NOT hit the rev limiter when on the juice!
2- Wide Open Throttle switch, You don't want to be on button with out enough air moving thru.
3- Fast FI box, Locks the fuel injectors at 100% duty cycle(fully open) when the nos is activated. You can also tune with this box by adding fuel, just cant take it out. Been out for years. Can also tune nos hp via jet sizes.
http://www.mpsracing.com/products/MPS/fi01.asp
4- If you still want more, place a hobbs(fuel pressure) switch on the fuel line. I would only use this on a system with fast fi box with an upgraded fuel pump.
Also 1 and 2 can be purchased as 1 unit. And to get a fully stealthed system go with a swopper switch.
Always remember tuning is the key.
Get on the line and drop it!
The Nitrous Advice Forum
tslewisz
posted September 22, 2006 10:07 AM
WTF is a "swopper switch"?
smiddy1
posted September 22, 2006 03:06 PM
Sorry about that, should be "swapper switch"
http://www.mpsracing.com/products/MPS/as13.asp
tslewisz
posted September 22, 2006 09:07 PM
Gotcha. Are you associated w/ MPS? I've never used their stuff, but I've heard good things.
smiddy1
posted September 23, 2006 07:52 AM
Not at all, just showing things that should help some people out. I've used some of thier products and they do work well.
0.29629182815552 seconds processing time
