BIKELAND > FORUMS > ZX-14.com > Thread: Holed my radiator today NEW TOPIC NEW POLL POST REPLY
halvefast
posted September 10, 2006 07:29 PM
Damn... it was such a good ride to end it like this sucks!
Must have caught a stone, smelled something at a stop light.
But made it home, never flashed HOT, but just barely made it.
I've got to come up with a guard before I put it back together.
Does anyone know for sure if these can or can't be repaired?
I'm sure they aren't cheap to replace.
While I'm in there as good a time as ever to wire the fan to a switch.
ECTA Ohio Mile 195.132mph
posted September 10, 2006 07:45 PM
Wow that sux! I've heard of motorcycle aluminum radiator repair shops, but never have had to see about one of mine being fixed. Here is a link I was sent a while back (and noticed the dude shows some before and after pics of his work):
http://www.motorcycleradiators.com/
posted September 10, 2006 07:57 PM
I did not even bother to price one out.
Mine happened the same place almost identically, but on the other side....
JB weld.
I cut out the fins about 1/4 inch on either side of the hole, and used a dremel and roughed up the area, cleaned it well with brake cleaner, pinched the split slightly and applied JB weld. 2 coats 12 hrs apart, used emery cloth to roughen up the 1 st coat of JB weld once it cured. Then applied the 2nd coat.
Used a black paint marker to cover up the gray patch.
The local radiator shops told me there was a good chance they would burn the aluminum before they got the silfoss... high strength high temp soldering rod to melt.
Agreed that a good high temp epoxy would be the best bet.
I have put over 4000 km on it since .... good stuff!
I have seen people use JB weld to repair cracked clutch covers on dirt bikes, and epoxy putty to fill holes in truck differentials, and seems to work very well.
I know it seems like a temporary fix, but i have seen this stuff endure years of use.
posted September 10, 2006 07:59 PM
oh yeah, Cox makes a screen for them ... finally.
Its stupid you know, the z1000 has a screen, why not ours....
posted September 10, 2006 08:10 PM
There is a new one on Ebay right now ....... O miles it's off a brand new bike ....
blitzkrieg
Road kill = Free lunch.
posted September 10, 2006 08:13 PM
I run Cox Racing radiator guards on both my bikes.
I can't speak for the 14, but a 12 radiator will cost you over 400 donuts. 430 if memory serves me correctly.
Good luck getting it fixed.I found several shops that would repair it, but none would warranty the repair. Doesn't do me much good 300 miles from nowhere.
posted September 10, 2006 08:49 PM
the rad shop told me this is how they repair many of the aluminum rads on cars today, and have never had issue, as long as its prepped properly.
The Cox racing guard just became avail. last 7-14 days... otherwise I would have been running one.
I knew that a rad would be min. 2 weeks away, and the repaired part is stronger than the paper thin rad itself.
I pressure tested it to 18 psi, which is about 6 psi more than the system should ever see, unless the rad cap fails. Since I slightly pinched the hole shut with needle nose pliers, the hole epoxy will never see pressure over a wide surface area anyway, its just sealing a micro crack, not a hole.
Lots of construction and dirty roads where I live, and buying a new rad for $500 + dollars really would piss me off if it happened again.
If you prep it right and use high temp 2 part epoxy or JB weld it will not leak.
Flame On
Fuel Air & Spark
posted September 10, 2006 09:10 PM
HOLY SHIT !!!! After seeing this thread whent to Cox and orderd one 65.00 duckets
77 RD 400
80 GS1000 GT
06 ZX14
INTIMIDA2OR
RED rider!
posted September 10, 2006 09:12 PM
Damn dirty roads
'06 Passion Red ZX-14
*Lee*
raptor14
posted September 11, 2006 01:22 PM
Damn! Just when I thought I had finished my mods for this year I gotta buy and install something else. I don't know whether to be pissed at this site cause all the good ideas are breaking my bank account or because all the good ideas are making my bike run better and safer. Anybody got experience with bolting one of these covers on the 14? Easy, hard?
raptor14
posted September 11, 2006 01:24 PM
OK, OK, all the good ideas are making my bike run better and safer. I ain't pissed. Thanks for sharing the experiences and suggestions.
Flame On
Fuel Air & Spark
posted September 11, 2006 01:51 PM
Should have one by Thursday will post after install.
77 RD 400
80 GS1000 GT
06 ZX14
blitzkrieg
posted September 11, 2006 02:37 PM
Not the 14, but an R1 and zx-12r and I am sure the 14 install is very similar.and straightforward.
Basically you have to have a clean line of sight to the front of the radiator. The R1 and zx-12r guards have a mount for the lower radiator support and zip tie to the upper mounts. Very straightforward.
I had my plastic off when I installed them so it was a no brainer, but I probably could have installed both with just the inner fairings removed. Rule is if you can see the entire radiator up to and including the entire perimeter you are good to go.
speedgene
posted September 11, 2006 04:00 PM
It's repairable. Take it to a radiator shop. They'll pressure check it before it leaves the shop.
It can be fixed at home with a little solder and a torch. But it will take a few hit and miss tires before you get the hang of it?
E-tard
nabrxx
posted September 11, 2006 05:47 PM
Based on what I just read...I just ordered one from cox....Thanks for the info!!!
What we don't understand, we can
make mean anything... src="http://www.bikeland.org/board/i
mages/smilies/smile.gif" border=0>
Jim K
posted September 11, 2006 05:55 PM
Pics?? Links??
Never did get the whole "Harley" thing!
Flame On
Fuel Air & Spark
posted September 11, 2006 06:21 PM
http://www.coxracingroup.com/
77 RD 400
80 GS1000 GT
06 ZX14
chez
posted September 11, 2006 06:34 PM
Try www.radguard.com.au
Chez
  Ignore this member    Click here to send Chez an AIM message.
lietoome
posted September 11, 2006 07:07 PM
$195.00 =$146.474 USD
>>>>>www.radguard.com.au
No thanks.
nabrxx
posted September 11, 2006 07:40 PM
The cox guard was about 85 bucks with shipping....Whats the downtime and the repair cost worth?
posted September 11, 2006 07:52 PM
Had to pull the rad, to repair it properly....
cost me $15, but 1 day down, and luckilly it happened near work.
caught a ride home and picke it up with my truck.
PITA.
Also, coolant on my rotor, pads and frt tire... had to remove the pads and clean / scuff them.
Wiped down the rotors with brake clean too.
Coolant on your tires could take you down too....
Get a screen!
1BADZX12r
posted September 11, 2006 08:41 PM
screen wont help because im dropping ballbearings
Flame On
Fuel Air & Spark
posted September 11, 2006 09:19 PM
Is it that your bike is falling apart. Or just figured out a way to keep the 14 from passing you.
77 RD 400
80 GS1000 GT
06 ZX14
halvefast
posted September 12, 2006 05:53 AM
Throwing boulders is more like it.
Just kidding 1Bad, but for real your mine come Friday, you'll be on my track!
1BADZX12r
posted September 12, 2006 07:53 AM
i get a drum of oil and pour it in your lane halve
0.27644395828247 seconds processing time
