BIKELAND > FORUMS > ZX-14.com > Thread: Raptor14's Fairing Removal, Exhaust & PC Installation Instructions NEW TOPIC NEW POLL POST REPLY
raptor14
posted August 29, 2006 02:32 PM
Due to the large number of requests via e-mail or through this or other boards I have finally made a clickable link to my instructions for removing the fairing and installing an aftermarket exhaust and Powercommander. In this case, the exhaust system is the Gen3 StreetSmart 4-2-1 From Brock's Performance Products. However, most, if not all of the instructions should be applicable to other aftermarket systems. Please note the comments:
1. Step 11 discusses tightening the header flanges prior to assembly of the headers. After
discussing this with Brock, a better procedure is to leave the flange nuts loose until the
system is installed. Tighten afterwards. This allows for some movement of the flanges
during assembly. I had no problems with my method, but Brock's comment is an
improvement.
2. Step 11 does not specify a required torque for the header flange nuts. The torque should
not exceed 10 ft-lbf, which is not very tight. Again, this spec came from a later discussion
with Brock.
Glad this is proving to be useful to those looking to improve their bikes. Enjoy your 14!!
http://members.cox.net/allengeo/ZX-14/Installation_Instructions.pdf
posted August 29, 2006 06:23 PM
I'm guilty of telling everyone how helpful the directions were for me. Prolly resulted in one or 2 of those mails. Thanks again!
BlueLIGHTning
posted August 29, 2006 06:30 PM
Just printed it and now just waiting for Brock's system to arrive next week. Do you have to remove the tank totally or can u just prop it up to remove the flies?
raptor14
posted August 30, 2006 03:35 PM
As much as zx14.net gets trashed, there is actually some good info out there. iflyphi provides a nice step-by-step write-up with pictures on removing the flies. You can see how he supported the tank. The link is provided below. I can never save the files from zx14.net with the SAVE command so I simply copy everything and paste it into MS Word.
http://www.zx14.net/publicforum/index.php?PHPSESSID=7f6640ca1b9ec5ce5226b50e9f9e3c83&topic=1046.0
BIKELAND > FORUMS > ZX-14.com > Thread: Raptor14\'s Fairing Removal, Exhaust & PC Installation Instructions NEW TOPIC NEW POLL POST REPLY
0.21891093254089 seconds processing time
