BIKELAND > FORUMS > ZX-14.com > Thread: Speedo Error NEW TOPIC NEW POLL POST REPLY
flyboy
posted August 12, 2006 05:47 PM        Edited By: flyboy on 12 Aug 2006 19:54
Speedo Error
I was curious about the accuracy of my speedometer so I set up my GPS on my bike.
As a pilot I have three Garmin GPS's and my portable is a Garmin 296 which runs about $1,600. It connects with 12 satellites so it is one of the most accurate GPS's made, if not the most accurate. It's also WASS capable. (means it's accurate)
Facts are as follows:
Vin #- 2253
Mileage- 1,400 miles, approx 30% wear on tire (unable to measure trend)
Gears- Stock 17/41
Speedohealer- Transparent mode
GPS accuracy- 13 feet
Trial runs - 3
Margin of Error- +/- 1.5 mph
Speedo - GPS
20 mph - 17 mph
30 mph - 28 mph
40 mph - 37 mph
50 mph - 46 mph
60 mph - 55.6 mph
70 mph - 63.3 mph
80 mph - 74.2 mph
90 mph - 83.7 mph
Are the Kawasaki engineers trying to keep us out of trouble or are they just poor at precision?
Part 2 speeds to follow.
fastestbusaaround
I eat Fish...
posted August 12, 2006 06:04 PM
This is by design on all sport and many sport touring bikes. It is likely what you said...trying to limit their liability (speeding tickets). Every sport bike I ever had had this issue, except my FJR, which was off like 1.5%. 7-8% high is the norm for most of these types of bikes.
FYYFF!!!
FasterThanStink
posted August 12, 2006 06:08 PM
Almost every bike I know has the speedo read high. Probably a legal thing. If they read low people would blame the mfg. for some of the more minor speeding tickets.
They also have to factor in the possibility of people fitting different brands of tires with small differences in diameter. Better to be on the conservative side and have them read high.
That's what gets you.
posted August 13, 2006 12:07 AM
145 mph indicated was 123.5 GPS for me.
serius blk
posted August 13, 2006 05:56 AM
On the sprockets calculations page the bike will do 204 at 10800. This past weekend the bike was pulling to 11k. I made it to about 10800. My rear tire has wear on it. So i would say at least from 195. It took sometime but it kept pulling.
fastestbusaaround
I eat Fish...
posted August 13, 2006 06:11 AM
195 indicated=180.375 true...on the 14, against a GPS. When they do top speed measurements, they are real speeds using radar, not indicated speeds on the speedo. Your bike will never do 195 without serious engine mods and a broken or patched speed limiter.
FYYFF!!!
serius blk
posted August 13, 2006 06:23 AM
FBA i the sph set at -20 so i cant tell what the speedo says. The bike has the usual mods so far besides nitrous and gearing. Im using the tach for a idea of the speed. The speed sprocket math calculation said 204 at 10800 rpm. I only said 195 because my tire is worn. Im sure that would be an under measurement. Besides the math calculations is what im going by. It seems that every gps is different but the math calculations always stay the same. With the mods and a lighter ride. The bike may have gotten to 11k alot faster.
fastestbusaaround
I eat Fish...
posted August 13, 2006 02:38 PM
Best way to set your SH is to go buy a GPS and see the exact difference...once done, return the GPS for a refund...
FYYFF!!!
BobC
posted August 13, 2006 11:48 PM
Further to this, fitted an 18t sprocket last week and now the speedo is correct.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
posted August 14, 2006 01:31 AM
Not only is that consumer fraud, but it's not the best way. Best way is to put the bike on a dyno. Run it at whatever your normal cruising speed is (140kph, whatever) as indicated on the dyno, then set the speedohealer appropriately. Run it up to speed again to verify and you are done.
zxlnt
posted August 14, 2006 02:50 AM
Swft what's to say the dyno is accurate?
fastestbusaaround
I eat Fish...
posted August 14, 2006 06:20 AM
Sorry dude...but all major electronics retailers including Costco (who is a large GPS reseller), have a no questions asked, 30-day money back guarantee. I am a large GPS distributor and I deal with all of them. This 30-day guarantee exists in the US and Canada. We get units back from people who buy them for a trip and return them...no questions asked. There's no fraud there at all.
2) Dyno...it won't account for wheel slippage
3) GPS is way more accurate than you think, especially when compared to a Dyno. Even the consumer GPS units are accurate on speed to less than .01%
4) Best to use tools that will reflect real road use...not test Dyno's IMO.
FYYFF!!!
tuusinii
posted August 14, 2006 10:54 PM
Yes GPS are very accurate in measuring speed and You should also remember that the postion accurance the GPS shows has next to nothing to do with the speed accurancy because the speed is not calculated from the positon but on a different method wich is very accurate even if don't have many satellites showing.
sp00ky
posted March 25, 2007 08:43 AM
Does this mean it clocks up more miles than it's acctually done????
Conventional Weapons Cannot Kill ME
Xtremespeed
posted March 25, 2007 10:30 AM
The odometer is almost dead on. Only the speedometer is off.
Yea, it sucks!
When in doubt, Flick it!
posted March 26, 2007 09:52 PM
since using my GPS a few days, I can not beleive the amount of speedo error Kawi provided me!
fastestbusaaround
I eat Fish...
posted March 27, 2007 01:21 AM
8.5% when compared against yer Zumo I bet...
FYYFF!!!
Xtremespeed
posted March 27, 2007 08:37 AM
About 7.5% for me.
posted March 27, 2007 08:43 AM
It's not the accuracy of the GPS I'm talking about, it's the slew rate. It can't measure speed instantaniously, so there is always an inherent lag. And with regard to tire slippage on the dyno, there is zero if you are just holding steady speed. Tire slippage occurs during accelleration runs, not zero-load steady state running.
chez
posted March 27, 2007 03:38 PM
who looks at the speedo anyway? I just ride off the tacho. Yellow box fixes speedo error.
Chez
  Ignore this member    Click here to send Chez an AIM message.
Xtremespeed
posted March 27, 2007 03:53 PM
And makes the gear indicator srew up.
BobC
posted March 28, 2007 04:45 AM
I suppose you know the tacho is optimistic by several percent too.
Stock wheelbase
0.2356870174408 seconds processing time
