BIKELAND > FORUMS > ZX-14.com > Thread: IVAN'S TRE TESTED! , Save your money. NEW TOPIC NEW POLL POST REPLY
CrazyKenny
posted June 01, 2006 06:32 PM
I gotta be honest , I guess I was looking for the silver bullet fix and got a bb instead. It makes a very, very small difference. I almost Think I would rather have my gear indicator work as apossed to the wee difference in pick up of the throttle. Now if we could just reprogram that darn ECU or get that second plate to work sooner!
posted June 01, 2006 06:34 PM
Thanks for the info ....Thanks...... Money saved for other mods ....
zx12mark
posted June 01, 2006 07:50 PM
what's the deal with the gear indicator?
Stalwart
posted June 01, 2006 07:55 PM
I believe it tricks the ECU into believing the bike is in 6th all the time, thereby making more power available.
Stuart
Ridin' the Trump train.
FasterThanStink
posted June 01, 2006 08:25 PM
Thanks for the heads up Kenny.
The bike is new. Give the computer boffins a little time. Where there is $$ to me made, someone will have an aftermarket fix. It may take some time to do it properly. I can wait.
That's what gets you.
posted June 01, 2006 08:58 PM
it thinks its in 5th, so full timing advance for all gears.
Thanks for the heads up!
zx12mark
posted June 01, 2006 09:02 PM
read again lady's.he said... GEAR INDICATOR....
posted June 01, 2006 09:10 PM
The indicator reads either 0 in neutral, or 5 in all other gears.
The ECU is fooled to think its in 5th so that the engine gets full timing advance.
fastestbusaaround
I eat Fish...
posted June 02, 2006 02:55 AM
The large power dip under 5K isn't the result of timing only (if at all), so no TREEEEEEEEEE's gonna make any difference...we need an ECU firmware mapping fix.
FYYFF!!!
Gary
posted June 02, 2006 03:39 AM
Wait for the (..wide band)... to come out, with a 20 minute read out ,so you can fine tune after a short ride and then you can adjust between gears, to do away with the low end responce..
zerMATT
posted June 02, 2006 04:00 AM        Edited By: zerMATT on 2 Jun 2006 05:01
The "wide band" PC is not going to have the ability to open the secondary butterfly in lower gears... that's not going to fix our problem. It's not entirely a fuel mixture issue on these bikes like bikes of the *past*.
fastestbusaaround
I eat Fish...
posted June 02, 2006 04:59 AM
+1 Needs ECU firmware remapping....or something to aid the ECU in remapping...
FYYFF!!!
swiftkart
posted June 04, 2006 10:55 AM
The 14 is set in 6th gear all the time not 5th, 6th suppose to be the best fuel/ignition curve on the 14.
The worst part of it is you lose (3) of the trick items on the 14, you lose the gear indicator, shift light and launch light.
posted June 04, 2006 11:59 AM
+1
Agreed!
BIKELAND > FORUMS > ZX-14.com > Thread: IVAN\'S TRE TESTED! , Save your money. NEW TOPIC NEW POLL POST REPLY
0.21246719360352 seconds processing time
