BIKELAND > FORUMS > ZX-14.com > Thread: Removing front sprocket / clutch assembly cover? NEW TOPIC NEW POLL POST REPLY
CrazyKenny
posted May 17, 2006 04:45 AM
Has anyone figured out how to get the counter shaft sprocket cover off yet. I have removed all the bolts and it will not come off for me. Does clutch master have to be removed?
swiftkart
posted May 17, 2006 06:44 PM
Just the forward one of the clutch master needs to be removed, it helps hold the cover on also.
posted May 17, 2006 08:47 PM
Thanks ...I will be installing my 16 tooth soon .....Nice to know what and what not to remove ...
swiftkart
posted May 18, 2006 04:21 AM
Installed mine Tuesday.
CrazyKenny
posted May 18, 2006 04:58 PM
Who would of thunk it! thanks a million!
posted May 18, 2006 05:00 PM
Hey don't go away !!!!! tell us what you think about that 16 tooth???? More punch ??? Pull harder??? come on spill the beans man !!!!!!!
posted May 18, 2006 05:23 PM
beans is not a good word round here...
swiftkart
posted May 18, 2006 06:39 PM
All of that and some. The things are geared for over 200 mph @ 11,000, taking 1 tooth off makes the thing really pull like crazy! Before it was a smooth increase and before you knew it you were hauling ass, now you can really feel the acceleration big time!
TheVak
posted May 19, 2006 07:13 PM
Just wondering what is effected by changing the front sprocket anything??
Does the chain sit right or is a change needed ??? So it really helps the low end
huh. What brand counter sproket did you get ?????????????
  Ignore this member    Click here to visit thevak's homepage.
CrazyKenny
posted May 20, 2006 06:20 AM
Got the cover off , Now I can't get the sprocket nut off, sounds weird but I can't get my damn NUT OFF!!!
swiftkart
posted May 21, 2006 09:20 PM
Vortex sprocket...make sure you undo the lock washer tab and then it will come fairly easy.
0.21636295318604 seconds processing time
