BIKELAND > FORUMS > BIKE CHAT > Thread: 01 Busa making clucking noise from shaft area NEW TOPIC NEW POLL POST REPLY
ranger1
posted June 17, 2009 11:03 AM
I have a 01 Busa with 30k miles. I noticed the other day when ridding it was makling a clucking sound from the area of the front sprocket. I jacked the bike on stands, started it up and put it into gear. After doing so it started to make this noise again. What can this be? HAs anyone else had this problem? Thanks for any advice..
posted June 19, 2009 09:11 PM
Get a zx14!
biggmoinc
posted July 10, 2009 08:28 PM
If ur chain is true (straight) with the sprockets then i would think it has been stretched one 2 many times n is in need of replacement. Also might want to look into changing both rear n front sprockets if u havent done so in 2 or so years. I run vortex rear sprocket n it seems to wear rather quickly. But the clicking sound could b the chain links r binding on the sprocket cause they r no longer matched perfectly due to the wear, just my opinion but i m sure someone else will help. I am learning as well, lol. Not everyone can just go buy another bike just cause the chain is worn, lol. But i do want a 14 eklipse636! Havent never ridden one but if it has the low end torque (flys out) like the busa, I NEED ONE!
biggmo@aol.com
Jon P
BusaGod
posted August 02, 2009 12:55 AM
Its chain drive NOT shaft drive moron!
posted August 02, 2009 01:08 AM
huh? :confused
Jon P
BusaGod
posted August 05, 2009 07:31 AM
No...... Just messing around.
Good luck with your issue.
Peace out!
0.23244690895081 seconds processing time
