BIKELAND > FORUMS > ZX10R ZONE.com > Thread: Tool for Adjust Rear Spring pre-load NEW TOPIC NEW POLL POST REPLY
agrobm
posted June 28, 2004 04:36 PM
Hi All,
Can someone tell me what tools they used to adjust the rear preload? My rear has virtually no sag and looking at my spring there's abotu 3 inches of thread showing so I want to adjust it.
Glenn
extremelean
posted June 28, 2004 05:31 PM
Here is a part # of a tool that KMC carries...... 57001-1533
I have used it several times on the ZX10...you have to remove the small plastic chain guard and removing the 2 bolts for your LH footrest stay helps...just leave your shifter hooked up.....Make sure you tigten all fasteners after adjustment is made (double check em!!).
agrobm
posted June 28, 2004 05:43 PM
Many Thanks EL.
bovinespongiformencephalo
variant Kreutzfeldt-Jakob
posted June 28, 2004 08:26 PM
Penske.
big daddy
posted June 28, 2004 09:06 PM
does it have a spacer??
BD
posted June 28, 2004 10:33 PM
Yes, it's intact. But I've heard you can take it out. If you have a good reason.
big daddy
posted June 28, 2004 10:49 PM
high speed stability.
BD
0.27769088745117 seconds processing time
