posted December 06, 2001 04:58 PM
Strapping the front end? Hey guys,
I'm an idiot. Do you strap a front end to (a) lower it or (b) control the amount of fork leg extension coming off the line, or (c) both? I've got the kennedy lowering links on the bike and I strapped it to bring the front end down. The bike handled so bad I brought it back up to stock height on both ends, and took the straps off. Any help would be appreciated!
posted December 06, 2001 05:34 PM
Lowering I lower mine to change the weight transfer. Makes it less prone to wheelie.
Of course its stock.
posted December 06, 2001 06:08 PM
When i get to the track, I get on a roll,mash the front breaks while pulling on the strap to crank the front down. Then i lower the rear, via a set of dog bones i made myself (threaded rods with heim joints) then its race ready. I wouldnt even think of riding it on the street lowered. I raise her back up when i leave....
posted December 06, 2001 06:38 PM
Make sure you fasten the strap to the bottom caliper bolts...otherwise your ZX12 fork legs will have a *franken-scar*...lol
posted December 07, 2001 12:05 AM
Yup...use the bottom bolts...
DON'T use the top bolts with the brackets turned to clear the tubes either!!! IT WILL CUT THE STRAPS as they age...
As you experienced swft...lowering SUCKS for street handling but...it makes a BIG difference at the drag strip...
The strap lowers the front and STOPS the front from gaining the upward inertia that it would on launch if it was left loose to extend upward...GOT IT???
posted December 07, 2001 11:20 PM
strap hmmm... That's news to me...I use the top bolts with washers so it doesn't mark the forks. What is the reason you guys are using the bottom bolts?
posted December 08, 2001 07:04 PM
Edited By: YTRAP on 8 Dec 2001 21:53
Permanent also Mines lowered 1" front and back. Tubes up in the triple tree and cut the springs on the back. I can still turn pretty good!
posted December 16, 2001 04:14 PM
I use a strap too, but I just drilled me some new holes to the side so my forks wouldn't get scarred like my first 12. Bike REALLY launches good using the bottom hole of my Kennedy links. Had to raise it to the middle hole since it was hitting my undertail and almost rubbing a hole in it. at first I thought I was burning the clutch a bit. Found the hole after three launches and raised it back up a lil. Strap gives me a better 60 ft and less wheelies. Less wheelies = less tickets for me on the street.
RED NINJAS RULE!!
