BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Clutch plate advice needed NEW TOPIC NEW POLL POST REPLY
uk mel
zx12r best 9.65 stock motor
posted December 30, 2011 12:02 PM
Hi folks. I'm seeking some advice about the clutch friction plates on the zx12. My question is Do i replace the odd narrow friction plate with a standard plate ? This would be the first plate that you install with the spacer ring. I will be running the 12 on the dragstrip more than on the road.
Many thanks in advance for your help
posted December 30, 2011 04:31 PM        Edited By: KZScott on 31 Dec 2011 00:32
I do. make sure you get out the curved ring and the flat ring, the flat one usually sticks
uk mel
posted December 31, 2011 10:16 AM
Thanks KZScott I was 99% sure it would be ok I thought I would check with the experts 1st lol. I'm sure I got both the rings out but I will check to make sure when I put engine back together.
NOX
PMRA / TMRC Super Street 4022
posted March 22, 2012 07:38 AM
Depends on which clutch you are using.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
NOX
posted March 22, 2012 07:40 AM
Standard Gen 1 lockup, or single stage, use the anti chatter rings. Use steels to get proper stack.
Hays, use all standard fibers, and use steels to get the proper stack.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted March 22, 2012 01:26 PM
I didnt use them with my MTC single stage. tons of ways to adjust stack height. 1.4, 1.6, 2.0, 2.3, and 2.6mm steels are available if you know where to buy
0.37233281135559 seconds processing time
