posted November 11, 2009 05:43 PM
how does contact patch compare?
posted November 12, 2009 03:00 AM
Hard for me to really compare as the 200 was wore down pretty low, so it was flat. Lol, it looked like the contact patch on the 200 was almost as wide as the 180! Out of all honesty, after this tire I will probably get a 190.
posted November 12, 2009 05:54 AM
Edited By: Shane661 on 12 Nov 2009 14:17
You oughta see the contact patch on a 330 tire! That's got to be the best....right?
posted November 12, 2009 06:37 AM
if they made an 11 pound 330 maybe
as far as i can tell the 190 shinko had just as much, if not more contact area than the 200 on a 6 in rim
posted November 12, 2009 06:44 AM
Edited By: Shane661 on 12 Nov 2009 14:54
There are so many variables when you talk about contact patch...depending on setup it can vary when using the same tire. The way the tire looks when mounted static on the rim is not the same way it looks when you launch the bike. Very, very quick bikes have run that Power Race 180 tire.
When I ran that Power Race 180 it hooked for me at 63.25", 16/45 gearing, 20 psi hot...on a 45 degree day. But my 60 ft's were only in the 1.50-1.52 range. Let us know how it works out on your setup, Eklipse.
posted November 12, 2009 07:02 AM
and if you can, get pics of the bike just after the hit. see how flat it goes
posted November 12, 2009 07:14 AM
Edited By: Shane661 on 12 Nov 2009 16:58
Here is an example of how much the tire can spread, even with 18+ psi in it:
Now that is the 190 Power Race, which I used for clearance (the 180 is taller), but it gives you an idea that what you see on the rim right now is not the way it is going to look when you launch it.
posted November 12, 2009 09:00 AM
thats great pic, just what i was looking for. i have a few pics of a 190 shinko looking a little flatter, but i was running maybe 10 psi then.
posted November 15, 2009 03:35 AM
kz scott, i have learned this weekend its not all about contact patch, its about grip! yesterday i ran 25 psi in the power race and that bitch HOOKED! they are going overboard prepping the track this weekened for the pro street guys but i didnt think it would hook.. well that little contact patch will not attempt to spin, none whatsoever. it actually took me 2 passes to understand how to take off, as i was use to a little tire spin.
posted November 18, 2009 04:43 AM
After 3 days of running 25 psi in the power race and had 9, maybe 10 passes throughout the weekend with temps ranging from maybe 55 deg to 80 deg (air temp) it hooked perfect! I don't believe I will run a shinko again. As long as I can find a michelin I'm sold on these. If I have to run a race takeoff I will before a brand new shinko. The michelin got me into the 1.3 60ft's. Now the question is how long will it last?!
ninjaboy311
posted November 18, 2009 05:47 AM
quote: After 3 days of running 25 psi in the power race and had 9, maybe 10 passes throughout the weekend with temps ranging from maybe 55 deg to 80 deg (air temp) it hooked perfect! I don't believe I will run a shinko again. As long as I can find a michelin I'm sold on these. If I have to run a race takeoff I will before a brand new shinko. The michelin got me into the 1.3 60ft's. Now the question is how long will it last?!
If you treat it just as you do a Shinko, it will last the same, if not maybe even longer.
I have 20 passes on the new Power One, and it still looks untouched.
posted November 18, 2009 06:04 AM
Edited By: Shane661 on 18 Nov 2009 14:05
Oh no, Dusty...you need to follow your original plan. Remove that tire immediately and get a 190, because of the 180's narrow contact patch. I'll give you $50 shipped for it.
NOX
PMRA / TMRC Super Street 4022
posted November 18, 2009 06:57 AM
Also depends on what grade of track you run on.
On good tracks, like tulsa and noble, my buddy ran a pilot, or metzler, all year, and it looks like it has some left. take it to our home track, and it gets ate up quick, because the track is not as smooth. I can get twice the life out of a mcr at tulsa and noble. at home, i eat them like a fat kid eating cake.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
posted November 18, 2009 08:06 AM
Ok ok shane I didn't have faith in the 180. It proved me wrong!
ninjaboy311
posted November 18, 2009 10:12 AM
No way Shane!! He bought it from me...so I get first dibbs!!! lol
ninjaboy311
posted November 18, 2009 11:28 AM
Found more Power Race 180-55 'soft' for cheap......
http://www.jcmotors.com/p-302-michelin-power-race-supersport-rear-motorcycle-tire.aspx
posted November 18, 2009 02:57 PM
What is the one I have? Soft or reg?
ninjaboy311
posted November 18, 2009 04:32 PM
quote: What is the one I have? Soft or reg?
The compound you have is PR-D (soft)
posted November 18, 2009 04:37 PM
Screaming deal for those tires!
ninjaboy311
posted November 18, 2009 04:43 PM
No kidding. If I had the money, I'd rack up on them.
2000redrocket
posted November 22, 2009 03:54 PM
i am going to probaly get one for the 12 so i have a maxton tire if i go next year it is already on. the shinko is getting thin and will need to be replaced eairly next year.
posted November 23, 2009 02:55 AM
If it is in the budget its much better than a shinko!!!
Bawls
re-learning to ride
posted November 23, 2009 07:44 AM
Edited By: Bawls on 23 Nov 2009 15:45
Nice... I'm probably going to order one as a replacement for my shinko. I'll try anything once... twice if i like it
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
posted November 23, 2009 01:52 PM
Bawls I don't think you will be disapointed!
posted November 26, 2009 06:27 PM
Time for a rear tire change:
Power Race 190/50/17:
This tire has about 150 dragstrip passes, 50 miles of top speed LSR runs, and a couple of hundred street miles. Plus around 50-60 dyno pulls. I figured it was a good time to change it since I could be looking at 40 passes this Saturday (and dyno time tomorrow).
Replacement tire, Power One 180/55/17:
It seems that the Power One is about 1 lb. lighter than the Power Race. This was verified on a UPS scale which weighed my Power Race at 13 lbs and the Power One at 12 lbs. The shipping weight of the Power One is listed as 11.6 lbs, and I think the UPS scales read a little high, based on my own results with two different scales.
The Power One has a much more flexible carcass, which should be good for drag racing.
The circumference of this tire measured at 79" on the 6" rim.
