BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: extra "oil squirters" NEW TOPIC NEW POLL POST REPLY
posted January 06, 2008 01:37 PM
how hard is it to put them in(a set of 12R cases)? just drill/tap and install? I have been reading up on why they would be used, and I think i might have found a reason to use them that may have been over looked.
they are to spray extra oil on the pistons to remove heat. some say this isnt required as they get sprayed with enough oil from "windage" as is. but this is what i found to be interesting. the muzzy "dummy shaft" (counter balancer removal shaft) works by removing rotating weight, and causes less "windage". so maybe with the muzzy shaft installed, there isnt enough oil being sprayed on the pistons, and the extra oil squirters would solve the "problem"
it makes sence to me anyway what does everyone else think?
TRNorBRN6001
posted January 06, 2008 04:10 PM
Go for it if it'll give you a little peace of mind. just make sure you have the correct angle.
TFA 200MPH CLUB MEMBER!
posted January 06, 2008 11:01 PM
anyone have pics? i have only read about it. im assuming the correct angle would be perpendicular to the surface?
woppi
posted January 06, 2008 11:10 PM
KZ
do it ! its not a big problem !
woppi
1st TFA Member / Austria !
2000 Limited ZX12R NOS
posted January 06, 2008 11:15 PM
thx for the pic Woppi!
just as i thought perpendicular just like the normal ones
woppi
posted January 06, 2008 11:25 PM
KZ
yes - they are stock - from an damaged old case !
woppi
posted January 07, 2008 02:20 AM
so... anybody have a set of squirters from banged up cases lying around?
woppi
posted January 07, 2008 03:31 AM
KZ
let me take a look ??
woppi
woppi
posted January 07, 2008 12:49 PM
KZ
sorry -- i lost my spare oil sprayers!!!!! - i am stupid !!!
but i have -- the kawasaki part number !!
the part number is = 92062 - 1086 nozzle
woppi
posted January 07, 2008 01:37 PM
thx Woppi
I have some pilot jets out of some old mukini roundslides... i wonder if they would work LOL
posted January 07, 2008 01:43 PM
Go to the Dealer or buy a few (You may damage or lose some!) on line from the Dealer in NC. Understand that on a Normal engine they will add heat to the oil and take away a few HP so to Off set you may need a "Real" Oil Cooler to take care of the additional heat in the Oil! I am going to do this because Of the heat generated by a 150 Shot of NOS. WHat is your reason?
posted January 07, 2008 02:06 PM
like i had up un the first post, im going to be running the muzzy dummy shaft that cuts down on oil windage. which equals less spray of oil in the crank case going on the pistons from that, so i want to "even it out" or get a little exra oil on the pistons. plus i do plan on using some nitrous down the road...
woppi
posted January 07, 2008 02:25 PM
some nitrous !
yes, yes, yes !!
spray it !
woppi
posted January 07, 2008 03:36 PM
just need to get it together and get the rest of the parts....
BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: extra \"oil squirters\" NEW TOPIC NEW POLL POST REPLY
0.31905508041382 seconds processing time
