BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: front brakes not dragging no mo' NEW TOPIC NEW POLL POST REPLY
posted July 31, 2004 08:14 AM        Edited By: entropy on 2 Aug 2004 02:10
Front brakes NOT dragging no mo'
a word of caution: this is NOT advice, it's just my experience, you might not wanna do it...
My front brakes had been dragging for a long time, wheel spun for minutes (literally) with pads backed off but was dragging when brakes seated. Would only spin a rev or so.
This morning:
1. pulled & completely disassembled both calipers.
2. "polished" all 12 pistons and cylinders w/1000 grit paper (thx for the tip Alan!)
3. replaced the pressure O rings with new ones (expensive lil fukkers)
4. ditched the dust o-rings
5. installed new-ish pads (don't know what kind, they were laying around the garage.
6. New Motul DOT 4 fluid; Mytivac-ed the bubbles out.
Whoa!!! It spins many, many, revolutions now, BIG difference, and it brakes better than ever!!
BA
posted July 31, 2004 09:15 AM
awesome dude! glad to hear it, sounds like a good tip to keep in mind!
your car is slow
Fuck Nitrous...Got Boost?
posted July 31, 2004 09:34 AM
Will be sure to try that out!!!
Do not taunt happy fun ball!
frEEk
posted July 31, 2004 10:48 AM
have heard a couple times that the dust pads are what tend to cause the dragging. be interesting to see how the brakes hodl up without them.
posted July 31, 2004 11:56 AM
I use the bike 95% on the track so I'm not too worried about losing the dust O-rings. but... just have ti see how it holds up.
bossman12r
posted July 31, 2004 07:11 PM
My front tire rolls like 3 times around and stops, it looks like the rotor is worped
gen 4 zx10 is fast
donwirux9
posted August 01, 2004 06:33 AM
After applying the brakes, if you were to lift the front end in the air would the wheel spin freely , or would there be some drag . I am just thinking about after the burnout ,its not like you can push the pistons away from the discs to get that free spining wheel again. Don
donwirux9
posted August 01, 2004 09:27 AM
Huh????
ZX12Girl
Adrenaline Junkie
posted August 01, 2004 10:05 AM
Thanks for the information Entropy!!! Every little bit helps.
Ra12r
posted August 01, 2004 02:23 PM
Dang man,,,,,,,,,Now i got another project to do on the bike! smile
DIGGSMS
posted August 03, 2004 02:24 PM
BRAKES
Always remember to pump the brakes back up with tiny strokes instead of 2to3 big ones this keeps from rolling those seals that he took out. (it usually takes about thirty to fourty pumps) do not forget to either pump the forks or spin the wheel with the pinch bolts loose so the wheel centers on the brake. spin wheel and grab handful of brake (on stands) this centers everything.
BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: front brakes not dragging no mo\' NEW TOPIC NEW POLL POST REPLY
0.50920391082764 seconds processing time
