BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Spacer/shim between rotor+wheel ???s NEW TOPIC NEW POLL POST REPLY
RobertMcBeth
posted October 15, 2018 11:48 AM        Edited By: RobertMcBeth on 15 Oct 2018 18:53
Been working on bike lately,
This is what I’ve done
2004 radial forks
2016 R1 monobloc calipers
Zx14 rotors
Zx6r wheels
Problem I’m having and was too stupid to consider is rotor offset
Both rotors need to go outward approximately 2mm (going to get some better measurements)
I have leads from a few friends I’m checking into about having a set of rotor shims cut out of aluminum shim sheet material,
Thinking of using factory gasket on zx14 that goes between rotor and wheel as template
Is this safe?
Are their any rotors available from a different Bike that have offset rotors with the same bolt pattern?
posted October 25, 2018 08:36 AM
a solid spacer will be fine with the correct length bolts
RobertMcBeth
posted December 03, 2018 11:36 AM
Bet thanks again scott
All times are America/Va     Next Thread >
Quick Reply:
0.30224299430847 seconds processing time
