BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Temp gauge flashing??? NEW TOPIC NEW POLL POST REPLY
ddpete3
posted August 12, 2003 09:57 AM
Wormholes bike's temp gauge arrows are blinking, and the temp fan is not coming on....is the bike overheating? what's going on?
  Ignore this member    Click here to visit ddpete3's homepage.
frEEk
posted August 12, 2003 10:07 AM
possessed?
worm~hole
posted August 12, 2003 11:01 AM
..I just arrived home...once the I got the bike on the freeway and up to speed, the temp indicated 8~9 o'clock...flashed again as I inched towards the checkpoint...then back down to 8~9 at speed...could be the fuse for the fan, the fan's not coming on...time for the fan switch mod...no time to look or play...gotta button up my KLR...I just got the shims for the valve adjustment...if only the 12R was this easy...
who would do us harm.”
-George Orwell
worm~hole
posted August 12, 2003 01:03 PM
...so, where's the fuse for the fan?...is it one of the fuses under the black fuse cover on the tank cover?...can't find my shop manual or my owner's manual...need your help, please...is it time for the the fan switch by-pass mod?...Ozzy sent me the instructons, but I think I accidentally erased the instructions and other stuff when I did some work on my computer...help?...thanks
-George Orwell
frEEk
posted August 12, 2003 02:23 PM
worm~hole, not sure if this is the same thing ur experiencing, but the fan dont come on till WAY late on my bike too, long after a whole bunch of water has spilled into the resevoir (or onto the pavement as is the case with myself jsut now). i seem to remember it was no different before i mashed the bike. the needle had to be way up in the hot zone for a while before fans came on.
worm~hole
posted August 12, 2003 04:36 PM
...never experienced boil-over except when I'm cooking ...my fan usually comes on when the needle's at the 10 o'clock position...then its on for only about 60~120 secs...then it re-starts as needed....
-George Orwell
posted August 12, 2003 08:46 PM
The temp sensor on the radiator is probably bad. Ive seen this on 3 different bikes. I think it costs $20 or so. YOu can jump the wires in the mean time till the new sensor comes in.
EastBayDave
posted August 13, 2003 12:16 AM        Edited By: EastBayDave on 13 Aug 2003 08:17
I had the same problem on my bike when it was delivered.
The fan fuse was blown from the factory; causing overheating & the LCD to flash. The dealer could not figure this out...
I bought a service manual & it's the FIRST thing on the cooling system troubleshooting page.
The fuse is located on the top of the "tank." Check it FIRST before you do anything else.
My bike would overheat anytime I was not getting wind into the radiator on a hot day...around town, lights, traffic, etc...
There is a spare fuse in the box...
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
worm~hole
posted August 13, 2003 01:48 AM
...thanks to all of you who helped this brutha' in need!
-George Orwell
posted August 13, 2003 02:15 AM
was this the prob?
worm~hole
posted August 13, 2003 02:41 AM        Edited By: worm~hole on 13 Aug 2003 10:45
...dunno yet, but I think its the fuse (I hope)...haven't checked it yet...multi-tasking bullshit right now...I already have my KLR apart in the garage for the valve adjustment...don't wanna have two bikes torn apart...need to run the bike up to hi-temp or get a multi-meter to check electrics, but no time today...I hope its simple, tho...I'll keep you posted...
-George Orwell
posted August 13, 2003 03:33 AM
Feel lucky its just your "Temp Gauge" flashing.... and not HarryZX12 flashing ya.
ScaredyCat
posted August 14, 2003 09:23 PM
Boil-over can be caused by the rad cap seal being fucked - it's spring-loaded to open at a certain pressure, check the cap seal isn't damaged, or try changing the cap? Might be a cheap fix....
If it ain't broke, BREAK IT.
  Ignore this member    Click here to send ScaredyCat an ICQ message. Click here to add 313822511 to your ICQ list.
worm~hole
posted August 15, 2003 07:27 AM        Edited By: worm~hole on 15 Aug 2003 15:31
...checked all fuses...they are good...looks like I need to check the switch?...in stock and not too expensive I hope...can anyone provide the part number for this part?...everytime I call the dealer, they always want the part number...as if the end-user should know this...they have the fiche...why can't they help a customer out and look it up...I'm already buyin' the part from them ferchrissakes!
-George Orwell
worm~hole
posted August 15, 2003 07:45 AM
...one dealer qouted the fan switch at $76.67!!!!!...for a little itty bitty thermo switch?...he qouted part # 27010-1418...is that correct?...would a by-pass switch be ok to run until I get a new switch in?...and what do I need to do to fashion this by-pass switch?...can it be turned on without the ignition "on"?
-George Orwell
worm~hole
posted August 15, 2003 10:27 PM
TOP
-George Orwell
worm~hole
posted August 16, 2003 04:04 AM
halloo?????
-George Orwell
posted August 16, 2003 09:22 AM
Well if its your typical dealer.. yeah thats probably the retail x2 price. Did you try Ron Ayers?
FWIW, you can also buy an adjustable thermo switch at an autoparts store. Usually runs $30 for the complete setup.
zx12richard
The Green Monster..
posted August 17, 2003 07:23 AM
Temp sensor was 72 dollars for me.... Short the two wires across and if fan comes on the sensor on radiator is bad.... I have had a back up switch on every since it failed.......
worm~hole
posted August 17, 2003 08:01 AM
...I'm not electrically inclined...how does one 'short' the two wires?
-George Orwell
posted August 17, 2003 10:06 AM
Take the two wires from the switch and put them on a toggle. When touched together, they will activate the fan.
worm~hole
posted August 17, 2003 10:51 AM
...that is so simple...thanks! ...I guess the horrible recall of when as a young child I 'accidentally' stuck my tongue on a 9v battery still haunts me
-George Orwell
EastBayDave
posted August 17, 2003 10:57 PM
try a "three-phase" shock........yyeeeeeooooowwwccccchhhh!
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
magzx12r
posted August 18, 2003 11:09 PM
My fan switch went out on me, but was replaced under warranty. After that, I installed a manual fan switch just in case it goes out again. I spliced into the two wires going to the fan switch in the radiator and ran the two "new" wires to a toggle switch I bought from Radio Shack. I mounted the toggle switch in the plastic cover over the ram air tubes. The good thing about the manual fan switch is that you can cut on the fan as soon as you get in stop and go traffic and keep the temp from getting two high.
Mark
'03 ZX-12R
'12 1199S
worm~hole
posted August 19, 2003 03:00 AM
...no thank you, Dave...the thought is making me shake and sweat....
-George Orwell
0.3815929889679 seconds processing time
