BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Sand in Airbox? NEW TOPIC NEW POLL POST REPLY
tbbt
posted June 09, 2003 07:16 PM
Sand in Airbox?
Any of you guys found sand in your airbox?
Here are some related threads:
http://www.zx-12r.org/phpBB2/viewtopic.php?t=15274
http://www.zx-12r.org/phpBB2/viewtopic.php?t=15955
AKA: T^2
X-ZZR-Guy
posted June 10, 2003 05:28 AM
tbbt,
I wouldn't have thought it's too much of a problem as long as your filter is sealed properly. I have driven cars in the desert and they used to get services every 500 miles.
Cheers!
TedG
posted June 10, 2003 07:02 AM
I was getting dirt from around the access covers, also I coat the inside of the airbox with grease to help catch any dirt on its way through.
Ted
2000 Green ZX12 sold
The fast color!!
Green 2005 ZX10R
2009 Concours Black ABS
TBBT
posted June 10, 2003 07:06 AM
Ted - I was thinking the same thing. The gaskets on the airbox caps look almost flush on the cap. The effectiveness of the gaskets look a little suspect. So how did you resolve the access cover (caps) issue?
AKA: T^2
TedG
posted June 10, 2003 08:24 AM
I took some silicone sealer and put a small bead around the edge of the cover( over the foam o-ring) after cleaning it with acetone. Then I put a thin coat of oil on the airbox where the covers come in contact (so the silicone wouldn't stick) and bolted it together very lightly. Let the silicone dry. Now the sealer stays with the covers and allows access without having to reseal each time.
Ted
The fast color!!
Green 2005 ZX10R
ScaredyCat
posted June 29, 2003 02:34 AM
tbbt,
yep, I got it too. It's not coming through the filter, it's ex-factory sandblasting grit material.
(Just got a new ZX12 and it was already there).
I cleaned it all out, and I'll be watching for more appearing.
If it ain't broke, BREAK IT.
  Ignore this member    Click here to send ScaredyCat an ICQ message. Click here to add 313822511 to your ICQ list.
ScaredyCat
posted June 29, 2003 03:50 AM
Can you see this pic?
This is what I found inside my brand new bike's airbox. Look familiar?
http://www.t35.com/scaredycat/dscf0005-1.jpg
You can see the sand easily where I've rubbed a finger through it.
Maybe this is one of the reasons that K increased the running-in period 'cos there had been failures?
0.2351701259613 seconds processing time
