BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 02 zx12 no spark NEW TOPIC NEW POLL POST REPLY
gearheads101
posted December 29, 2013 06:36 AM
02 zx12 no spark
First off I'm new to this forum, I have 2 problems 1st what model is the 02 zx12 A1 or A2? 2cd I have no spark to my plugs' and the fuel pump only cycles when the motor is turning over. bike will not fire up. It was laid down by previous owner and it hasn't started up since. What could the problem possibly be.
Burn Rubber not your Soul!!!
Lou_ZX12R
One Day at a Time
posted December 30, 2013 05:53 AM
There is a tip over switch that would cause this problem. Check the manual on how to reset it.
2000 ZX12R 40shot
2012 ZX14R
2009 Concours 14
gearheads101
posted December 30, 2013 06:17 AM
OK I'll check it when I get home I notice your sign of is zx12 40 shot, what kinda plugs are you using
Lou_ZX12R
One Day at a Time
posted December 30, 2013 07:31 AM        Edited By: Lou_ZX12R on 30 Dec 2013 23:31
Iridium plugs but same heat range as stock. NGK
2000 ZX12R 40shot
2012 ZX14R
2009 Concours 14
gearheads101
posted December 30, 2013 07:50 AM
OK sounds good was told that you have to use colder plugs with nos I ordered a now kit on eBay but having installed yet because I can't get it to start, also did a valve adjustment because the valves were very tight. Bike only has 7300 miles do you no what model is the 2002 zx12
Lou_ZX12R
One Day at a Time
posted December 31, 2013 09:26 AM
Sorry, I can't help you with the model. Good luck with the bike, it's one of the best to have.
Lou
2000 ZX12R 40shot
2012 ZX14R
2009 Concours 14
0.25460004806519 seconds processing time
