BIKELAND > FORUMS > ZX12R ZONE.com > Thread: I NEED SWINGARM ADVICE NEW TOPIC NEW POLL POST REPLY
BA
posted April 14, 2003 01:25 PM
Ok guys, now that I have 2 swingarms, I'm sending the fooked up one to be extended.
I REALLY, REALLY want the adjustability-factor, but I'm concerned about all this "how do I support the brake bracket" nonsense.
I'm thinking that I want a 0" - 4" adjustable arm.
Supposedly, my stock brake bracket will not work.
What are my options??? Are people just bolting on a new, diagonnal support arm or is there another option?
This one's not adjustable, but a nice pic. none the less.
posted April 14, 2003 02:11 PM
I am speaking from a "Little" Experience here I have 2 suggestions. #1, Send it to Doug at Spencer Cycle. #2, Ask if they can modify the brake bracket with a 1/2" thick by 1" wide bar that slides under the Billet extension. That way, you can have "Full adjustability" and strength in resisting movement when on the brakes. I will draw a picture and fax it to doug if no one gets the picture!
If life is not hard enough and you feel the need for punishment foe wanting the "0" part, Get in touch with me and I will tell you where to send it for sure :oops
posted April 14, 2003 02:46 PM
Two words....BOLT ON Extensions...alright, so it was 3 words...hehe
jonwright
posted April 14, 2003 03:43 PM
That's assuming you use the rear brake anyway....
So how's a bike handle in the twisties after an extension like that? Does it help to back it in a 30 mph curve at 75?
BA
posted April 14, 2003 04:07 PM
....there *are* no twisties in Dayton.
posted April 14, 2003 04:13 PM
Dayton Ohio?? Head South East The extension must be removed and remounted where the 0 to 4 or 0 to 6 keep to chains and a bunch of press on and rivet master links and a serious chain tool T will do my Lasn Speed Racing and some Drag Racing then change for June July and August and late September change back for Land speed racing!
spencercyclecom
posted April 16, 2003 08:08 PM        Edited By: spencercyclecom on 16 Apr 2003 21:09
V. Hill wrote>>>>wide bar that slides under the Billet extension. That way, you can have "Full adjustability" and strength in resisting movement when on the
okay...ONE LAST TIME>>>> Our arms ALLOW the full travle of the brake arm. We designed ours to be like this from the get go, it is the other out there that have yet to get with the program.
Doug Ray
SpencerCycle.com
SpencerCycle Center Inc.
Spencer Performance Group Inc.
Toll Free 1-800-510-1945 ext #10
International 1-800-510-1945 ext #11
Local/Tech 1-704-642-0987 ext #12
Fax 1-704-642-0987
BA
posted April 26, 2003 01:02 PM
Bumping!
Is anyone using an adjustable are is everyone at fixed length!??!
As I mentioned above, I *already* have the swingarm! It's the same one that got fooked up when my rim bearing went out.
your car is slow
Fuck Nitrous...Got Boost?
posted April 26, 2003 02:02 PM
im ordering the bolt on extensions...best bang for the buck IMO.
I was a bit leery of the "strength" issue just by lookin at the pictures..but seeing them on Ricks GSXR1000....those damn things look 10x stronger than the arm itself.
Very very solid piece of work...has me sold.
Do not taunt happy fun ball!
kangpow
posted April 26, 2003 02:41 PM
Which bolt on extensions are you ordering ?? Where can I check them out at ??
kcadby
posted April 26, 2003 02:57 PM
Max-V (Doug Spencers X-partner???) did John's when he was still with Doug...nuther words...it went through Doug's shop...I think...
AS DOUG SAID...John's adjusts fine although John's IS only 4-6 over...
They just make the "slot" that rides on the swingarm tab longer by adding a piece to it to make it longer...
WORKS FINE!!!
spencercyclecom
posted April 26, 2003 04:40 PM
MAX-V was NEVER a "partner". I ONLY rode a drag bike he had. Thats all.
As for the swingarm YES we do them and yes the brake provision is a longer slot milled into the block that we weld in the arm. i do not have pictures of the slot..but you do use your stock caliper bracket wiht our arms...we only modifie your claiper braket to work.
Doug RAY
SpencerCycle.com
Doug Ray
SpencerCycle.com
Fax 1-704-642-0987
your car is slow
posted April 26, 2003 06:32 PM
Im ordering them from Gixx1300R@aol.com
he posts on LAB from time to time...been makin them for awahile now.
I think the 3 - 6" extensions run 275.00
spencercyclecom
posted April 26, 2003 07:00 PM        Edited By: spencercyclecom on 26 Apr 2003 20:03
You may want to check these out. The bolts never need to be chaged if you want to go short or longer wheelbase. price is $270.95 AND you can purchase them via our website
http://prosites-spencercycle.homestead.com/zx12bolton~ns4.html
Doug Ray
SpencerCycle.com
Fax 1-704-642-0987
your car is slow
posted April 26, 2003 07:02 PM
those are very nice doug....I havent ordered Gixx's yet...what is the cost on yours?
Id be a spencercyle ad whore for a deal
(by the way...did those brake lines ever show up...the mixup should have been cleared up by now)
spencercyclecom
posted April 26, 2003 07:04 PM        Edited By: spencercyclecom on 26 Apr 2003 20:05
yes the did...thanks price is $270.95. Go to our website and read about the differences in these and the others out there
Doug Ray
SpencerCycle.com
Fax 1-704-642-0987
your car is slow
posted April 26, 2003 07:11 PM
can you flip the rear brake caliper upside down and utilize the stock brakeline? or is a custom length line required?
kcadby
posted April 26, 2003 09:34 PM
Sorry Doug...
Someone (I don't remember who) told me you and he worked together at one time...
My Bad...
kcadby
posted April 26, 2003 09:36 PM
Missed you Bri...
I went to CAW on the ZRX12 we have...
spencercyclecom
posted April 27, 2003 02:33 AM
a longer brakline is required....we have those and custom make them to fit your bike
No prob...KCaby.
Hey KCaby....do you know anyone with a used ZX12r engine...a good running one or a rebuildable one?
Doug Ray
SpencerCycle.com
Fax 1-704-642-0987
your car is slow
posted April 27, 2003 06:12 AM
sorry bout that kev....I had a wedding to go to last night..and didnt get home in time to fix the bike to ride
02zx12rbob
posted April 27, 2003 10:17 AM        Edited By: 02zx12rbob on 27 Apr 2003 11:19
Bolt-on is the way to go.
BA
posted April 27, 2003 07:51 PM
Hey Doug, those adjustable bolt-on's DO look nice!
First pair I've seen like that...... (thought I already posted this yesterday!)
jonwright
posted April 27, 2003 08:03 PM
Heh heh. Yeah, I know. I just wanted to hear it.
Whose yer daddy? Whose yer daddy? WHAT's MY NAME??? SAY MY NAME!!!!
Oh yeah. Wrong forum.
TWISTIES, MAN!
Jeez. I really feel sorry for you flat-landers. Ten seconds and yer done. I go all day.
Hope your time during sex isn't comparable to your rides......
HOOO BOY! We're off topic and startin' some sheeit now! YEE HAW! IT's GOOD TO BE ALIVE AND PISSIN' YOU FOOKERS OFF!
jonwright
posted April 27, 2003 08:04 PM
Yeah. Ignore previous post.
I never said that.
Just ask Iraqi Bob.
0.30855202674866 seconds processing time
