BIKELAND > FORUMS > ZX12R ZONE.com > Thread: o5 gsxr 1000 NEW TOPIC NEW POLL POST REPLY
biggmoinc
posted June 08, 2012 09:38 PM
o5 gsxr 1000
I know wrong forum but the gsxr1000 forum on bikeland is not busy enough for this to b viewed
05 gsxr1000 problem
05 1000, bike ran perfect prior to engine removal, got engine head n cam package from npsracing done, put engine in, started it for heat cycles, didn't go over 4k, bike only got to 160 temp before I shut it off, exhaust was glowing red, spark plugs look fine, actually didn't even look like they got wet (fuel ) bike runs like its starving for fuel, like the older gsxr when running low on fuel before u turn to reserve, took pump n fuel rail and injectors out, cleaned them all out, bike still runs boggy, like its not on all cylinders, there's 2 plugs under tank, 1 white 3 wire n a 2 wire clear plug that aren't hooked up, I font believe they were hooked up from the beginning, any ideas, oh, n removed 2ndaries plates prior to install, could removing them cause this
biggmo@aol.com
0.22943687438965 seconds processing time
