Thread: not starting |
agressor
posted June 08, 2012 10:12 AM
not starting
Hay Guys
I have some serious problem.
Bike is after head mill. It has PCIIIr, akrapovic full system and k&n filters.
Full service done, TPS set up stock, removed clean air system.
I have some problems after rebuild, bike was running badly to 4000 over that rpms it was OK.
few days ago guys in workshop were checking valve clearance (and want to tune it on dyno)
but after valve job they cant fire it up (all valves are perfect and cams are in stock position)
It gets fuel, there is spark and it cranks and thats all.
We even put directly fuel in to throttles but it didnt start.
We try with power commander and with out. Nothing.
What it can be? Any ideas?
Regards
drjohnzx10
posted June 12, 2012 10:53 AM
First try simple stuff like new plugs make sure u gap them
agressor
posted June 12, 2012 10:44 PM
Yes I think also its something simple.
Dane
posted June 15, 2012 07:18 AM
.02 Check the tps connector and map connector....werent they the same config. IDK justa thought.....
agressor
posted June 18, 2012 07:06 AM
Thanks Dane for info, I thought about it and everything is ok with conection,
maybe in workshop someone missed this.
Now there are racing team mechanics work on it so I hope it will be ok.
| Quick Reply: |
