Thread: Flywheel Needed ASAP |
Rossi
posted March 10, 2012 05:15 PM
Hey ya'll, have'nt been on here in a while do to my deployments in the military eating up my time but here is my issue. Need a new flywheel from the generator / alternator. This is going on my 2002. I was hopeing the flywheel off of my 2000 would fit it but learned that lesson the long way. Not using my 2000 since my X friend layed it down. Anyway if you are curious, yes I went through the steps direct from the manual and had the correct continuity but the voltage was way to low. .4 ohms and about 50V @4,000. New battery and my old battery do the same thing of dying after about a half hour of riding. Checked with my good friend at the bike shop and he said either the stator coil or flywheel / rotor. Narrowed it down to the fly wheel kaw. part #21050-1195. I'm not wanting to spend almost $400 for a new one, so if anyone has any suggestions I would greatly appreciate it.
Thanks,
Chris
zx12mark
posted March 10, 2012 06:19 PM
any parts you need on e-bay motors.........check there .
Rossi
posted March 11, 2012 11:45 AM
There was one on e-bay but it looks like its pretty beat up. Who knows how long until that one loses its magnetism and won't work. Thanks for the thought but im going to have to find one in better condition somewhere.
ZXLNT
posted March 16, 2012 12:25 PM
I think I have a couple spare flywheels, let me check. I think I have one of each, post a picture of yours if you can so I can match it up with what I have...
WarDawg
posted May 02, 2012 03:25 PM
Hey ZXLNT
I'm in need of one also for a 2001 12R. Do you have one for that year?
Need ASAP if you do.
herbg26
posted May 04, 2012 03:55 PM
Edited By: herbg26 on 4 May 2012 22:56
I got one 2000, attached to the crank that needs a couple journals fixed. Somebody can have, just pay shipping cost, I Think within the us will be about 40 bucks...I just need to get rid of this thing...PM me
HERB
Kawasaki lover
WarDawg
posted May 11, 2012 10:21 AM
quote: I got one 2000, attached to the crank that needs a couple journals fixed. Somebody can have, just pay shipping cost, I Think within the us will be about 40 bucks...I just need to get rid of this thing...PM me
Can't PM you so just replying here
Whats the part number on that flywheel?
HERB
herbg26
posted May 12, 2012 05:48 AM
The crank and flywheel are off a 2000, so the flywheel part number is 21050-1185
I can send you pics, just give me your address
Herb
Kawasaki lover
Bigbore4
posted May 13, 2012 02:44 AM
Probly wasting time and money if you think it's the flywheel. The flywheel is a magnet. Check the stator and/or rectifier unit. You said 50 V output? Any of the ecu operated systems have overlimit protection.
Rossi
posted May 13, 2012 06:08 AM
Altenator needed I figured out. Been out of it from major back surgery. Anybody have one?
peanut 12
peanut 12
posted May 15, 2012 05:26 PM
yes 65.00 shipped
chuckster1228
posted October 15, 2012 07:18 PM
do you still have the fly wheel i need it email me at chuckster12281969@gmail.com thanks
chuckster1228
posted October 16, 2012 02:38 PM
Hey herbg26 I need the flywheel if you still have it email e at chuckster12281969@gmail.com thanks chuck
DeathProof
deceased
posted January 06, 2013 06:30 PM
I have a flywheel for your newer zx12r. 2000 and 2001 models wont fit and as the other riders on here have suggested you need to check the rectifier for output and voltage and also replace the factory junction box possibly. The charging system is a problem on this bike but remember that if you buy a high output stator from rick's you will also need to buy a high output (mosphet) or rick's rectifier as well. Either full OEM parts only or all aftermarket hi output parts. There is a small hole in the stator cover to allow oil in. If you remove the factory metal gasket and use black rtv gasket maker instead, being careful not to plug the hole with material, you will increase the oil volume to the stator which will keep it cooler. Just compare the size of the hole in the spring steel gasket meant to feed the stator with the hole in the case and block for oil to flow. The restriction of the gasket makes cooling harder. Solder the new connections making sure not to use any burned portions in new connections and relocate the new rectifier to an external location that will ft more air flow.
| Quick Reply: |
