BIKELAND > FORUMS > ZX12R ZONE.com > Thread: zx12 gear postionn sensor NEW TOPIC NEW POLL POST REPLY
teamtaz
posted April 13, 2011 09:12 AM
does anyone know if you do away with gear position switch,i use engine in a autograss car so only need 1st and 2nd gear,
does engine give full performance when ecu is told engine is in neutral
cheers
tuusinii
posted April 14, 2011 12:16 PM
There is a different map for neutral in the ECU. What year is Your engine? 01 and after need a speed signal for speed restriction input or Bonneville box. I'd use 2nd or 3rd gear.
  Ignore this member    Click here to visit tuusinii's homepage.
almost_les
posted April 14, 2011 01:55 PM
yes. you can hardwire it to think its in a specific gear the whole time. there are seven wires in the connector going to the gear position sensor. one for each gear plus neutral. find which one is for the gear you want and ground the end going to the ecu to the chassis.
teamtaz
posted April 15, 2011 03:33 AM        Edited By: teamtaz on 15 Apr 2011 10:34
if i tell ecu iam in 2nd gear will that give me full performance of engine, il proberly have to re wire stater though coz i wont engage starter whilst in gear,bike is an 2002 b1 engine,cheers
almost_les
posted April 15, 2011 08:27 AM        Edited By: almost_les on 15 Apr 2011 15:38
im not 100% sure which gear is most power. i would assume 4th or 5th.
almost_les
posted April 15, 2011 02:09 PM
been looking at schematics, might be a bit trickier than originally thought...
Quick Reply:
0.195739030838 seconds processing time
