Thread: 00-05 upper fairing on a 2000 |
cm644rodrigues
posted February 09, 2011 02:59 PM
Hi i searched on here a little and couldnt find a good answer. Just wondering will a2000 -2005 upper fairing bolt up to the 2000 with the right headlight and upper fairing brace they look the same fitment wise i just like the headlights and the intake look better on the 2000 and up. thanks for your help.
shiphteey
posted February 09, 2011 06:50 PM
00-01 are the same....
02-05 are different.
A.
RnR Cycles
Loring: 229.6 mph (tailwind)
Bonneville: 201 avg, 208 (tailwind)
TX Mile: 200.2 mph (headwind)
Maxton Mile: 220 mph headwind (headwind)
Ohio Mile: 222 mph (spinning)
Street: Classified
posted February 10, 2011 09:10 PM
I saw one A with B bodywork. i think he had to switch most of the ram air system out too
07 MDP Rookie of the Year
01 ZX-12R 8.84 @ 156.3 no bars, DOT rubber, Pump Gas NA..... turbo 8.47 @ 164
00 ZX-12R 8.62 @ 165.2 no bars, slicks, Pump Gas, 55 shot
00 ZX-12R stock with bolt ons NA 203.694 Loring 2012
Warp 12 Racing!
shiphteey
posted February 11, 2011 09:52 PM
Pretty sure the A upper doesn't line up to the B side fairings, but I forget.
A.
RnR Cycles
Street: Classified
ZXLNT
posted February 12, 2011 06:07 AM
You need
Upper Fairing
Lower Fairing
Center Fairing
Headlight
Upper Fairing Bracket
City Light
Ram air covers
Ram Air Intake
Each is different between the A and B model.
KINGKWIK
9.36@ 149.23
posted April 17, 2011 01:08 PM
hey guys I have a 2001 with 2004 fairings. swapped them myself. Everything bolted up just fine. If i remember correctly i had to change only the ram air tubes as well.
If it has wheels or tits its bound to be trouble!!
posted April 17, 2011 08:17 PM
quote: hey guys I have a 2001 with 2004 fairings. swapped them myself. Everything bolted up just fine. If i remember correctly i had to change only the ram air tubes as well.
this would be the one i saw
Warp 12 Racing!
| Quick Reply: |
