BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 2004/2005 ZX-12 ECU Flashing NEW TOPIC NEW POLL POST REPLY
RidgeRacer
posted November 12, 2009 04:40 PM
I finally got around to opening up the ECU I got off of eBay (Kawi Part# 21175-0038). As I suspected it is a first generation 32bit with a 7052 cpu.
What that means is that it is the same type as the 02-07 Hayabusa.
It can be flashed through the wire harness connectors. You do not need to cut any holes in the ECU.
It can be flashed with a $20 USB cable, not a $200 adapter like the 16bit ECUs
The flash program is available free from the chip maker, not a $179 like the 16bit ECUs
I'm downloading the maps now. I'll let you know if I find anything exciting.
posted November 12, 2009 05:37 PM
I think its safe to say its about to get very easy to go fast with the 04/05s
capt10ed
posted November 12, 2009 05:49 PM
GREAT !!!
I can't wait.
My current was modified by Dave O (RIP) but for only extended rpm.
and 204.5 in the mile.
Texas12R
posted November 12, 2009 07:13 PM
well Ill be in line...........
Im sure one of you guys will be able to guide me along through the software
and a grateful thank you to Marlin.....or Merlin as some of us think of him
posted November 12, 2009 11:10 PM
Hey Ridge... I finally got all that info we spoke about, I will email you soon.
Thanks!
MM
sami1
posted November 13, 2009 04:06 AM
That's great to hear.
RidgeRacer
posted November 13, 2009 07:55 AM
Looks like typical Denso dual map setup with duplicate Ign, Fuel, and misc maps. Unlike the older 12s however it appears, at least on my bench, that you can switch maps real time. On the earlier 12s you had to turn the key off/on to change map sets.
If true this means newer 12 owners will be able to wire this into their nitrous set up and have automatic motor/nitrous ign/fuel map switching like the Busa guys have.
Also I noticed these 12s have an Air Switching Valve solenoid that is used on the exhaust air injection smog system. For those of you who have removed this system and put in place block off plates this solenoid drive channel would be available for other uses such as an RPM window switch or shift light.
2000redrocket
posted November 13, 2009 04:05 PM
wohoo
Texas12R
posted November 14, 2009 10:29 AM
What's the software? Is it the denso ETSI
and the interface cable to the ecu
sorry but this is all new to me
RidgeRacer
posted November 15, 2009 07:50 AM
No this is not Denso ETSI.
Since this is new to everyone let me cover some basics.
ECUs can have two types of programming modes. Boot Mode and User Mode.
When the ECUs are manufactured and the CPUs are installed they are totally blank. Boot Mode is used to program them and install the operating software. The Boot Mode software is burned into the CPU when it is manufactured.
User Mode consists of flash functions written into the operating software by the ECU manufacturer. Two ECUs designed with the same CPU, say one designed by Denso and the other Mitsubishi would have to different User Mode flash systems including passwords etc because the flash functions were written into the software by their designers, not the chip maker.
DENSO ETSI is a User Mode system. What we are doing to the 12 is a Boot Mode Flash.
Denso designed the ECU with all the necessary Boot Mode signals from the CPU present on the wire harness connectors. So we don't need to speak Denso to reflash it. In reality we are not reflashing a Denso ECU but the Renesas SH7052 inside of it.
capt10ed
posted November 15, 2009 08:03 PM        Edited By: capt10ed on 16 Nov 2009 04:04
What scary is that in order to make my 12 go faster I need to put busa parts on her.....at least no one will know....lol
Mauser
posted November 16, 2009 01:01 AM
So the boot side is a ROM and the flash side is like an EEPROM ? makes sense to me, so the plan is to download the current maps etc and then modify as required and reflash the unit in such making Power Commanders not needed for re-mapping. Got to be the way to go for the later ZX's also the fact you can do this from the existing wiring harness is a real bonus. I take it the Kleen air output could be used for driving virtually any device and programmed to switch when required ?. Maybe you could change the trip display into a gear indicator now that would be more useful.
RidgeRacer
posted November 16, 2009 07:05 AM
Actually the Boot and User Mode flash the same EEPROM space. The difference is in where the software that does the flashing comes from. The Boot Mode flashing software is burned into the chip at the chip factory and can't ever be erased or changed. The user mode flashing functions are written by the ECU designers and installed at the ECU factory.
One advantage the Power Commanders have is real time tuning while the engine is running. You have to stop the motor to reflash the ECU. Given that fact and the huge user base and experienced Power Commander tuners I don't think we will make them obsolete anytime soon.
The instrument clusters have their own little computer and software inside. They are not just a display for the ECU. To change the trip meter would require reflashing the dash, not the ECU.
sami1
posted December 09, 2009 12:07 AM
Any updates?
capt10ed
posted December 12, 2009 03:53 PM
zx12richard
The Green Monster..
posted December 12, 2009 05:24 PM
Have a 00 what could I gain with reflash
kiwi12
posted December 13, 2009 01:10 AM
Can I use a 04-05 ECU on my 03 ?
would i have to change the loom etc?
or is it a no go
what is going on in here?
Texas12R
posted December 13, 2009 03:40 AM
03 throttle bodies are different than 04-05
04-05 32 bit processor 03 still 16 bit I think
04-05 is a different harness
charging system is different in some aspects
might be more stuff
KarSung
How fast do you think....
posted December 28, 2009 11:32 AM
Any news on this????
Question: will this flash remove 186 speed restriction?
'04 Galaxy Silver ZX12R
capt10ed
posted December 29, 2009 07:56 AM
RR please do not give up on these GREAT bikes.
billgeo
HELL YEAH!
posted January 31, 2011 09:11 AM
This is killing me!!!
Is there a newer thread????
nooooot
KarSung
posted January 31, 2011 09:44 AM
I have not heard anything on this since 12/2009.....sounds as this mod is a NO go......oh well....life goes on!!!!
billgeo
HELL YEAH!
posted January 31, 2011 10:27 AM
I can see that the "hacking" of the SH7052 chip is going strong...
http://www.activeboard.com/forum.spark?aBID=99460&p=3&topicID=14204808
I guess that the "programing through the ECU connector" part didn't go so well,
or maybe it got shifted over to the BUSA units...
If indeed it is actually possible for the BUSA 32bit ECU to be reflashed via the connector
I would guess that a simple pinout map indicating the coresponding pins on the ZX12 ECU
would be all that's needed to get one started on reflashing the Kawi SH7052....
Right?
nooooot
capt10ed
posted February 05, 2011 05:45 PM
RR......Has anything happened ???
navpreet318
one crazy 12
posted February 15, 2011 06:11 AM
Any Updates RR?
Also what benefit would a casual rider make out of this modification.
My problem here is that i do not have a dyno here and the map is really off due to the climate and altitude.Can something be done to it?
2005 ZX-12R,Arata Full Ti, PC3,Gillis
Rearsets,Muzzy Velocity Stacks,BMC
Race filters.One Crazy 12
0.30139422416687 seconds processing time
