BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Swingarm swap question NEW TOPIC NEW POLL POST REPLY
Hells Dark Lord
living life, and loving it.
posted June 04, 2009 07:07 AM        Edited By: Hells Dark Lord on 4 Jun 2009 15:22
I find myself in a position to have to put a new swingarm on my 01 ZX12R...my question is this....
Will the swing arm off a newer B model fit on my A model bike? and if so , is it a direct swap, or do I need to do modifications?
I lost a cush drive bearing and the cush drive moved out and the sprocket nuts took out the swingarm....so I am redoing the rear end of the bike....
This includes a complet cush drive assembly for my Marchaseni rear wheel, with bearings spacers and sprocket and chain....not taking any chances when I put it back together, will put all new swingarm bearings and wheel bearings in it
So if anyone has any ideas on where I can get parts for that wheel please speak up.....I am not having much luck finiding the parts online.....
posted June 04, 2009 08:44 AM
It will fit bolt pattern wise in the frame, no problem!!!
But you need the dog bones and shock link from the B model swingarm!!!...If u dont have them, then ur rear height and shock possition will be different than 2000-01 OEM spec...
Hells Dark Lord
posted June 04, 2009 10:49 AM
ok I have turnbuckle style dog bones already, I will have to resource a B model shock linkage....or just put an Elka on it and have ride height adjust ability.....hehehehe
posted June 07, 2009 09:22 AM
Well then there is nothing you need!!!
0.70145082473755 seconds processing time
