brickman
posted August 15, 2008 07:10 PM
fi light
2000 fi light stays on all the time. bike has not been ride or run in a while so i pull it out fire it up and the light stays on. i have taking the pc off but no help. any one hade this happing to them? thanks
SHIGGSY
posted August 16, 2008 01:46 AM
It means you have a fault code, to read it remove the rear seat and lift out the storage box. There will be a yellow wire with a female bullet connector (on the right side as you stand behind the bike). You need to ground that to the frame. I have made up a wire with 2 male bullet connectors on either end, plug one end into the yellow wire, turn on the ignition and within 2 seconds ground the other end of the wire to the frame (non painted part) and hold it there. The FI light will then flash codes at you.
Two long flashes + three short flashes gives fault code 23.
Three long flashes + four short flashes gives fault code 34
etc etc.
Once it's given you all the fault codes it will recycle from the begining again.
To get to stored codes and not just present fault codes repeat the above but instead of grounding the wire once and holding, ground it 5 times quickly and then hold it.
Below are the fault codes:
brickman
posted August 16, 2008 01:41 PM
thanks i will give it a try.
brickman
posted August 19, 2008 11:48 AM
i found the problem the sensor on the right back of the bike was not hooked up. i put the plug back in and all is wail. thanks for the help.
