BIKELAND > FORUMS > ZX12R ZONE.com > Thread: front fork springs NEW TOPIC NEW POLL POST REPLY
aliveagain
posted August 07, 2002 05:57 PM
front fork springs
I was wondering if anyone ever needed to change the front
springs and oil . My forks come close to bottoming out just from braking hard.With that much movement I wonder how much i'll be able to lower the front forks in conjuction with dogbones.I'm 6'5" and 240lbs.
jason370
posted August 07, 2002 06:01 PM
alive,
how do you fit on your bike? i am 6'4 230 and its a tight squeeze to say the least. did you change seats, footpegs, riserbars?
jason
'02 ZX12 black/gold
  Ignore this member    Click here to send jason370 an AIM message.
posted August 07, 2002 06:34 PM
Go to www.racetech.com, and they'll have stiffer fork springs.
aliveagain
posted August 07, 2002 07:07 PM
no, my pegs and bars are both stock thanx for the info i find I have alot of room except for getting on the paint.Then I,m looking just over the screen.My last bike was a harley dresser so i,m still getting my muscles use to the bars
ZHooligan
Post Whore Extraordinaire!
posted August 07, 2002 07:32 PM
Race tech springs work really well. Also their fork oil holds up better then any other I have seen. I have been amazed at how clean the Race Tech fork oil stays. It is more expensive but lasts longer.
If you can afford it I would strongly suggest you send your forks to Race Tech let them revalve and respring you. Their work is outstanding.
future; -- Youth is forever.
wannabe
posted August 07, 2002 08:50 PM
Before you go of spending money, did you adjust the preload on the forks?
"There are only three sports: bullfighting, motor racing, and mountaineering; the rest are just games." - Ernest Hemingway
BA
posted August 07, 2002 09:16 PM
maybe I was hallucinating, but I thought I heard from a few folks that having 12R front springs go 'soft' wasn't an uncommon problem. Heck, Turbo810 and/or Judge had the problem too I think.
Mine are the same way. I was thinking about doing the RaceTech thing too but I just ain't got the cash now......
aliveagain
posted August 08, 2002 03:04 PM
wannabe, yes,I adjusted the preload all the way down with no luck. I measured using a tie wrap on the slider and it is within 3/4 of an inch from the bottom. I have a customized paint job on the front fender and bottom half of the fairing, springs are on 0rder. $100
redelk
Please... speak to the hand.
posted August 08, 2002 03:52 PM
You might be thinking about the nitrogen in the rear shock. The pressure does drop down over a period of time. I posted my experence with the rear shock on this thread...
http://www.bikeland.org/board//viewthread.php?FID=1&TID=3138
I also replaced my front fork springs with a "heavier" set from RaceTech. I took pictures of the process, if your are interested in doing it yourself. Just e-mail me at adcraft@cei.net.
-Ernest Hemingway
aliveagain
posted August 08, 2002 04:28 PM
redelk thanx but i,ll pass on shots . i,m having the dealer do it. I,m not set up with a front lift.by the way 22mm allen wrench or socket at msc in Milford,Ct.machine shop told me about it.
redelk
posted August 08, 2002 04:41 PM
Have them check the nitrogen pressure in your shock as well. Mine had gone down to 60psi (OEM is 142). They will need a shock valve needle to do it. The cap will also have to be removed. In the above mentioned post, I explain how you "save" the cap so you can reuse it. If your dealer removes it, odds are that it can't be reused. It's not that big of a deal, but it's nice still having the cap to keep out road trash.
-Ernest Hemingway
posted August 08, 2002 05:39 PM
At 240 you are waaayy to heavy for the stock .860kg springs. You need the 1.1kg springs! Any suspension guy worth his salt would know this.
FuckMeRunnin
posted August 09, 2002 11:51 AM
Race tech customer service sucks a big dick.
At least thats what lubricity's experience was.Hell,I wouldn't let them revalve Ninjamans custom hydralic dildo!
GMD computrack did my forks,revalved them,installed new springs matched to my weight.I also got a Penske rear shock with a spring to match my weight.They also set up my suspension for me and worked with me on adjusting while I was there (in atlanta,ga.)My bike handles like a totally different bike,much much better.I'm very happy with the way my bike is now.
"What happens if you get scared 1/2 to death twice?"
frEEk
posted August 09, 2002 01:28 PM
i'm startin to wonder if i'm sufferin from soft springs too. i only weight 170lbs, but even tho i have never felt the pegs scrape, i have scraped the shit oughta the bodywork in mid-lean. it feels like it's close to goin thru in a couple places. i can only imagine that my springs (and shock pressure?) are so soft that the suspension compresses too much from the lateral force, reducing the max lean angle to the bodywork. my fairings are both cracked anyway so i'm not too concerned about the current pair, but i dont want this to keep happening when i replace/repair them. any similar experiences? is my diagnosis at all plausible?
Eddynasty
posted August 09, 2002 02:12 PM
I'm trying to get the most out of the stock stuff. At 6-1 & 220 lbs. with only 500+ miles on the 02. I ran some posted 15 mph exit ramps today at 110 mph & felt comfortable. My main concern is how the bike will behave at 150+ mph.
Will someone post a sponsor or whatever where I can purchase a K&N air filter online? Thanks...Ed.
aliveagain
posted August 09, 2002 02:16 PM
mscdirect.com 1-800-645-7270 22mm allen socket
FuckMeRunnin
posted August 09, 2002 04:22 PM
K&N Filters here:
http://www.spencercycle.com/
feldguy2002
posted August 12, 2002 02:27 PM
6'4" Thats it? On my 12R, I changed the pegs and its the comfiest bike I've ever ridden.
beansbaxter
posted August 12, 2002 03:36 PM
Are the front fork springs different on the 02 model, compared to the other two?
posted August 12, 2002 06:03 PM
Dunno, but you can find out at www.buykawasaki.com, just look up the specs for each.
aliveagain
posted August 16, 2002 07:16 PM
just had the fork springs done and they still seem to be too weak.1.0kgs were installed which is the stiffest Racetech makes. sugestions?
posted August 16, 2002 07:29 PM
Umm...umm... No idea! Maybe a spacer inside for more preload?
m hackman
posted August 19, 2002 12:31 PM
FELDGUY2002
Did you find a lower set of rearsets?
0.29955911636353 seconds processing time
