BIKELAND > FORUMS > ZX12R ZONE.com > Thread: It's Kawasaki Saturday: Kawasaki Unveils 2007 and 2008 Models NEW TOPIC NEW POLL POST REPLY
posted September 23, 2006 08:00 AM        Edited By: fish_antlers on 27 Sep 2006 23:48
Some of this isn't new "news" as the Internet has been hemorrhaging photographs of a few of these bikes for the last month or so, but as always there are some surprises. Kawasaki has announced its 2008 replacement for the aging Concours, the ZX-14 based "Concours-14" (make sure to sign up at concours14.com to find out more about this model). Also for 2008 is a surprise, a redesign for the old and reliable KLR 650. 2008 brings us the new KLX450R, the latest incarnation of the Supercross Championship winning KX450F.
The big announcements for 2007 are the all new ZX-6R and Z1000. Both the ZX-10R and the ZX-14 fall under the "bold new graphics" department for MY07. The ZX-14 a little bolder than you might think (see photo on right). Missing from the North American market appears to be the motardish Kawasaki Versys. Will it make its way into Canada and possibly the USA through CKM? Too early to tell, but certainly a disappointment to not have this bike available Stateside. As usual we have included all of the specs available to us in PDF format.
Grab a cup of coffee and enjoy, as Bikeland presents Kawasaki Saturday!
CLICK HERE TO DOWNLOAD 2007 KAWASAKI MODEL INFORMATION INCLUDING SPECS
2008 KLR 650
NEW 2008 KAWASAKI KLR650 REFINES ON-ROAD CAPABILITIES FOR IMPROVED TOURING PERFORMANCE
Tougher, faster, more comfortable and better-performing than ever
The new KLR650 is well suited to life on the highways, deserts, mountains or even the challenging terrain of today's urban jungle. For 21 years, the Kawasaki KLR650 has been the smart choice for riders seeking reliable on and off-road performance. Now, the 2008 KLR650 features thorough updates aimed at making it a better tour-ready dual-purpose bike than ever before.
Featuring new suspension and brakes, the KLR650 is a fun, functional commuter during the week and an adept dirt road blaster on weekends. The new 41mm front forks now have less static sag for a taut, smooth ride on pavement. Front suspension travel is reduced from 9.1 in. to 7.9 in.
A redesigned UNI-TRAK® linkage reduces sag and compliments the new front suspension by reducing rear wheel travel from 8.1 in. to 7.3 in. The 2008 KLR650 features enhanced stopping power, thanks to a new 280mm petal-style front brake rotor that's similar to ones used on Kawasaki's Ninja® sportbikes. Rear braking performance is also improved, thanks to a new rear brake calliper. These new suspension and brake upgrades boost the KLR650's on-road performance, without diminishing its versatile off-road capabilities.
Several new refinements help make the KLR650 an even more worthy touring companion. There's a larger rear luggage rack that's 3.5 in. longer and 5.1 in. wider than the old rack, and a new, narrower tail section which makes it easier to mount saddlebags. Wind protection is also improved with all-new bodywork featuring a taller windscreen and large shrouds. A large 6.1-gallon fuel tank and miserly fuel economy
mean the new KLR650 retains its legendary range between fill-ups.
Riders will be able to take full advantage of the KLR's range, thanks to a revised seat design and new urethane foam for greater long-distance comfort. A high-capacity 36W alternator powers a new higher-output headlight and offers extra capacity to power the add-on electronic gadgets touring riders can't live without.
The KLR650 motor, already renowned for being rugged, reliable and powerful, is now even better. There's improved throttle response from a new throttle position sensor and revised ignition mapping, and revised cam timing contributes to improved high-rpm performance. A redesigned cylinder head boasts new intake porting for greater low-end torque and quicker throttle response in city traffic, as well as improved top-end power for high-speed cruising on the open road.
More on-road competence doesn't mean less off-road fun. The KLR650 has a U.S. Forest Service-approved spark arrestor for access to any road open to licensed vehicles, and a tough engine guard protects the engine from loose rocks and gravel. With an optional Kawasaki tank bag and soft luggage on the larger standard rear rack, KLR650 owners can tote enough gear for an extended trip to any remote location.
All these improvements mean that more than ever, the new KLR650 is the ideal go-farther, multi-surface motorcycle for riders craving on and off-road adventure.
2008 Kawasaki KLR650 Features and Benefits
651cc Four-stroke Single
- Revised cam timing contributes to improved high-rpm performance
- New intake porting offers greater low-end torque
- New piston rings are thinner and have more tension, for improved oil consumption
- New one-piece exhaust pipe features smoother bends for improved exhaust efficiency at all rpm
- Special tuning to improve low- and mid-range power
- Light, silent cam chain reduces engine noise
- Oil-level window permits easy and accurate inspection
Liquid Cooling
- New Denso radiator is thin and lightweight. Fitted with a lightweight and thin cooling fan, the new radiator has a greater cooling area and offers a 20% increase in cooling efficiency
- Maintains consistent engine temperatures for long engine life and sustained power during hard use
- Allows tighter engine clearances for quieter running
- Automatic fan keeps things cool in all conditions
- Includes a temperature gauge
Four-valve Cylinder Head
- Better breathing for more power at all rpm
- Compact combustion chamber allows increased compression ratio with less detonation
- The use of a secondary air (ASV) system helps reduce harmful exhaust emissions
- Provides maximum valve area for optimum flow
- Boosts low-end torque
Double Engine Balancer
- Engine runs smoothly from idle to redline for rider comfort and less fatigue on long rides
Fully Transistorised Ignition
- Fully transistorised ignition unit replaces the earlier analog CDI for better ignition performance
- More precisely controls timing no matter how fast the rpm changes
- Fewer moving parts for long, trouble-free life
Five-speed Transmission
- Designed to handle the engine's unique power characteristics
- The engine's broad torque curve only requires five speeds for off-road and relaxed highway cruising
- O-ring drive chain reduces maintenance and increases chain service life
Handlebar-mounted Choke
- Convenient location makes starting and warm-up easier
Revised Front Suspension
- New, beefier 41mm front fork is offers increased rigidity. (Previous unit was 38mm)
- Re-calibrated suspension offers less static sag and now offers greater on-road riding performance.
- Front suspension stroke was reduced from 9.1 in. to 7.9 in.
- Air-adjustable front forks
- High-mounted front fender for any adventure-touring situation
Revised UNI-TRAK® Rear Suspension
- Rear suspension travel was reduced from 8.1 in. to 7.3 in.
- New D-section swingarm contributes to the bike's excellent traction
- Redesigned UNI-TRAK® linkage compliments front suspension changes
- Progressive rate provides a smoother, more controlled ride
- Features a five-way preload shock absorber with four-way rebound damping
Stronger Wheels
- New 4mm spokes (up from 3.5mm) provide increased wheel stiffness, enhanced handling performance and improved steering response.
Semi-double Cradle Frame
- Made of high-tech, round-section, high-tensile steel
Engine Guard
- Protects engine from rocks and trail debris when the going gets tough
Detachable Rear Subframe
- Simplifies maintenance by providing better access to the rear shock, airbox and carburetor
- Large rear cargo rack included
Front and Rear Disc Brakes
- New lightweight front and rear petal discs offer excellent braking.
- Front brake disc diameter increased from 260mm to 280mm.
- New rear calliper offers improved feel and power
Electric Starter
- Easy and convenient starting
Lighting and USFS-Approved Spark Arrestor
- New dual-bulb headlamp offers greater night visibility
- New high-mounted turn signals improve the KLR650's visibility at night or under poor visibility conditions
- Rear taillight parking light
- U.S. Forest Service-approved spark arrestor
Large 6.1-gallon Fuel Tank
- Significant capacity permits adventure touring
Additional Comfort and Touring Features
- All-new bodywork features a larger fairing, which contributes to increased wind protection
- New, easy-to-read instrument panel is mounted to the frame, contributing to lighter steering
- Full instrumentation includes a large-face speedometer, tachometer, odometer, trip meter and water temperature gauge
- Firmer urethane seat foam offers greater comfort for long-distance riding
- Seat height is lower, but reduced suspension sag means the rider's ability to reach the ground is about the same
- Alternator output has been increased from 14.5A to 17A. Total capacity is 36W to provide ample power for the new headlight as well as add-on grip heaters and other accessories
- Optional extended warranty
2007 NINJA® ZX™-6R
KAWASAKI DELIVERS 600-CLASS POWER WITH HANDLING INSPIRED BY 125 GP MACHINES
Quicker and more exciting than any middleweight Ninja sportbike in history
Designed to place its rider on the top step of the podium, the new Ninja ® ZX™-6R sportbike elevates 600-class power and handling to the next level. Considering the stellar capabilities of last year's ZX-6R, Kawasaki's designers knew it would take a special combination of middleweight power and nimble handling characteristics if they were to make the next leap in middleweight performance. To hone the incredible new machine into an exciting racetrack weapon, Kawasaki appointed a former 125cc Grand Prix racer as the ZX-6R's chief development rider. The result is an all-new 600 capable of cornering speeds previously unknown to the middleweight class while retaining the wide spread of power that is pure Ninja.
To be quickest around the racetrack a motorcycle requires a wide powerband and plenty of over-rev. The ZX-6R's all-new engine was redesigned from the crankcase up for the first time in ten years, leading to an ultra-high-rpm powerplant that produces more mid-range torque than any of its predecessors. The result is a fat powerband with a linear torque curve for hard-hitting acceleration across the entire rev range. The Ninja ZX-6R's impressive over-rev capability mimics a true race bike, allowing riders to stay on the gas where lower-revving machines are forced to shift.
The Ninja ZX-6R's all-new engine was also specially designed to reduce internal friction. That's because low-friction engines tend to be more responsive, making it easier for the rider to modify cornering lines with minor throttle adjustments. The new engine components were also made stronger, stiffer and more compact, resulting in an engine which is about 40mm smaller in both width and length than its predecessors.
This compact engine allowed the chassis designers to create a slim and compact chassis. Other racing technology includes a close-ratio cassette transmission that makes it easy to keep the Ninja ZX-6R screaming at its horsepower peak and a slipper clutch which allows quicker downshifts without upsetting the rest of the chassis.
In designing the Ninja ZX-6R's chassis, the development team concentrated on creating a motorcycle that would make fast entry and mid-corner speeds feel easy. A compact, lightweight design allows it to maintain more cornering speed throughout the turn while entry speeds are enhanced by the slipper clutch and powerful radial-mounted front brake calipers. Complementing this track-biased package are fully-adjustable front and rear suspension units. The entire package of frame, suspension, engine and bodywork was designed to enhance the ZX-6R's fun-to-ride factor by offering a more exciting ride. The results are faster cornering speeds, quicker lap times and even more worried looks on the competition's faces.
The frame and swingarm were developed with an optimized balance of rigidity, so the Ninja ZX-6R responds instantly and precisely to the rider's every command. Mass centralization, engine mount locations and a variety of other factors were optimized to help ensure instant turn-in characteristics. Once in the turn, the Ninja ZX-6R holds a line with precision and tracks through the apex as if it were on rails.
All these features mean chassis feedback is very precise, with the ZX-6R communicating every move directly to the rider. The machine responds more precisely and predictably to control inputs and shifts in body weight. The result is a motorcycle that makes the rider feel like a part of the machine.
The new Ninja ZX-6R offers the power of a high-performance 600 Supersport racer mated with the nimble handling characteristics of a small-displacement GP machine. Let the competition compromise performance for rider-friendliness; the new ZX-6R was designed to take home trophies and set the quickest lap times, while being more exciting to ride than anything else in the middleweight sportbike category. The Ninja ZX-6R is a pure expression of Kawasaki's racing philosophy.
2007 Kawasaki Ninja® ZX™-6R Features and Benefits
Key Features
- Incredible power-to-weight ratio
- Race-oriented performance
- Track-tuned handling
- Aggressive new aerodynamic styling
High-Revving 599cc Four-Cylinder, DOHC Engine
- New compact, narrow and lightweight design features a tri-axis crankshaft and transmission shaft layout to optimize the engine's center of gravity. This helps reduce pitch changes during heavy braking and gives the rider more-accurate feedback from the chassis
- Narrow engine design allows excellent ground clearance
Four-Valve Cylinder Head
- Compact valve train reduces cylinder head height
- Intake ports and coolant passages were developed using flow analysis for efficient cylinder filling, more power, and maximum cooling efficiency
- Forged sintered aluminum spring retainers are half the weight of steel retainers and allow higher rpm
Forged Pistons
- Forged pistons are lighter, stronger and more heat resistant than cast versions.
Ram Air Induction
- Central ram air duct produces a straighter path to the airbox for maximum intake efficiency and provides the mounting surface for the instrument panel, eliminating brackets and weight
- Flow analysis used to design efficient ducts to the airbox that also prevent water from reaching the air filter
- Compact airbox and air cleaner are highly efficient and contribute to the compact riding position
Digital Fuel Injection
- Shorter throttle bodies deliver improved over-rev characteristics
- Smaller throttle bore diameter helps produce more torque in the mid-range
- Ultra-fine atomizing injectors improve combustion efficiency, for better power output and lower fuel consumption
TCBI Ignition with Digital Advance
- High-speed 32-bit ECU processor provides precise engine management
- Spark plug-mounted ignition coils are compact and help reduce weight
Pre-chamber Equipped Under-seat Muffler
- New exhaust pre-chamber is located below the engine and contributes to better mass centralization
- Revised under-seat silencer is significantly smaller and lighter to help mass centralization and allow for a more aerodynamic tailsection
- New exhaust header design contributes to improved exhaust efficiency
Six-Speed Transmission
- New cassette-type transmission features a racing-style gear stack to allow easier trackside ratio changes
- Close ratio transmission increases circuit performance
Racing-Style Slipper Clutch
- Racing-type slipper clutch reduces chassis disturbance when making rapid downshifts. This allows the rider dedicate more attention to braking and setting up for the corner
- Optional springs, spring retainers and shims are available to fine-tune the clutch for specific track conditions
Gear Position Sensor
- The convenient gear position sensor gives instant information to the rider, this is especially useful for improving consistency when testing new settings on the racetrack
- The system compatible with the semi-automatic shifters (legal in AMA Supersport racing) which temporarily cut ignition to facilitate clutchless shifts at full-throttle
Lightweight Twin Spar Aluminum Perimeter Frame
- Combination of pressed and cast aluminum components are welded to form the twin-spar perimeter-type frame. By combining cast and pressed pieces frame weight is kept to a minimum while still providing high strength and stability for responsive handling
- Chassis features optimum center of gravity for easy roll response, this is particularly important when riding through a series of esses or returning to vertical as the rider exits a corner
Uni-Trak® Rear Suspension
- New Uni-Trak® rear suspension system features pillow ball upper mount in place of the earlier bushings for a more direct feel and improved feedback
- Compact frame and engine allow a longer swingarm, which makes it easier to control rear wheel powerslides
- Rear shock is fully adjustable for preload, compression and rebound damping. Ride height can be adjusted by adding/removing optional 1mm shims at the upper shock mount
- Equipped with a top-out spring which improves the rear wheel's ability to follow the road surface when the rear end is light due to hard braking
- Small piggyback shock reservoir is designed to save weight
41mm Inverted Cartridge Front Fork
- New fully-adjustable 41mm inverted cartridge fork provides exceptional rigidity
- Equipped with top-out springs which allow the front wheel to better follow the road surface when the front end is light due to hard acceleration
- The main fork spring is located at the bottom of the fork. Because the spring is completely submerged in oil, cavitation is minimized, resulting in stable suspension performance even under demanding racetrack conditions
- Stiff settings are suitable for track use
Radial Mounted Front Disc Brakes
- Radial mounted four-piston, four-pad front brake calipers improve brake feel over a wider range of operation
- A separate brake pad is used for each piston. One large pad tends to deform with the heat generated by hard track style riding, resulting in a loss of brake feel at the lever. Individual pads provide increased cooling efficiency and can absorb more heat without deforming so they maintain consistent brake feel lap after lap
- Petal design brake discs offer excellent cooling and warp resistance
Aerodynamic Bodywork
- New design is the most aerodynamically efficient of any Ninja sportbike available today
- Light and compact projector beam headlights allow a more aerodynamic fairing
- The new Ram Air duct is small but highly efficient
- The exhaust system includes an under-engine resonator which allows the use of a smaller under-seat muffler. This helps to minimize drag by allowing a cleaner tail section design
- Integrated front and rear turn signals reduce wind resistance
- Three-piece front fender designed for aero efficiency
- Different color panels create a sporty, aggressive image
Riding Position
- New ultra-compact chassis places the rider in a ideal position to take advantage of the ZX-6R's improved handling capabilities, by improving the man-machine interface
- Slimmer fuel tank design makes it easier for the rider to grip the tank and seat when hanging off in a turn
Advanced Electronic Instrumentation
- Multifunction odometer, tripmeter, clock and lap timer/stopwatch
2007 Z1000
KAWASAKI'S NEWEST VERSION OF THE Z1000 OFFERS STYLE, FUN, AND PERFORMANCE
Kawasaki engineers have literally upped the ante in the naked bike arena with the introduction of the newly-redesigned 2007 Z1000. Offering both increased performance and the styling to complement the visceral riding enjoyment it provides, this purpose-built Kawasaki is sure to find a home in the garages of both practical motorcyclists—and those simply seeking a smile-producing weekend ride.
This latest incarnation of the Z1000 features a seriously bulked-up performance capability that is created by refocusing engine and chassis characteristics for serious street riding. With one liter of superbike technology, the Z1000's boosted engine performance provides greater exhilaration when passing or pulling out of corners. This version of Kawasaki nakedness has been tuned to satisfy the most demanding musclebike riders. Not only will its reconfigured torque measurements provide low-end get-up-and-go, but the increased pull follows through its mid-range, giving the rider extra thrust for conquering most road challenges.
Placing maneuverability at the forefront of the engineering task, Kawasaki has developed a new engine sub-frame and re-engineered chassis rigidity balance to provide truly outstanding feedback, enabling the rider to read and respond to all motorcycle behaviors, in all speed ranges.
Improvements in mass centralization and revised ergonomics have significantly enhanced the synergy between rider and machine.
The handlebars of the Z1000 have been positioned closer to the rider, and combined with a slimmer saddle,the result offers a more compact riding position. This, in turn, lets the rider take full advantage of the motorcycle's greater stablity and sharp, nimble, handling characteristics, while making short work of their favorite ribbon of asphalt.
A big increase in the "Fun to Ride" factor is an unavoidable side-effect when you couple a more powerful engine with a more maneuverable chassis. When it comes right down to it, isn't that what motorcycling is all about?
This particular model—perhaps more than any other—speaks to the intrinsically raw desire of the dedicated motorcyclist. While providing maneuverable, functional transportation in any daily environment, it provides the ability to unleash the fun-seeker in every rider. And it does it with Kawasaki performance and styling characteristics unmatched in the naked bike category.
2007 ZX-14
KAWASAKI NINJA® ZX™-14: THE WORLD'S MOST POWERFUL PRODUCTION MOTORCYCLE DOMINATES THE COMPETITION AT THE DRAGSTRIP AND ON THE STREET
Awesome power meets outstanding balance to deliver the ultimate ride.
Dominant is a word often misused to describe products which don't actually fulfill that promise. However, it is precisely the right word to describe Kawasaki's Ninja® ZX™-14. Since its debut in March of 2006, this motorcycle has won every major magazine comparison test it participated in. Earning universal praise for massive torque, effortless power, stable handling and a comfortable riding position, the 1352cc Ninja ZX-14 has set the highest performance standard in the motorcycle industry.
The ZX-14 isn't just a straight line wonder. It also excels with light, neutral handling and comfortable ergonomics which challenge dedicated sport touring motorcycles for rider comfort. Indeed, this most powerful of all Kawasaki-branded motorcycles was created to do everything right.
Just because a motorcycle has overwhelming power, doesn't mean it has to be intimidating to ride. With electronics tuned to deliver a predictable spread of torque in low-gear/low-rpm situations, the Ninja ZX-14 inspires far more rider confidence than expected from such a powerful motorcycle. A twist of the throttle delivers a seamless spread of torque that is so linear, the "power band," becomes irrelevant. Those that have ridden a ZX-14, marvel at a power delivery which makes it possible to pull away smoothly from a total stop in almost any gear.
The ZX-14's chassis design is every bit the equal of its power plant. An advanced version of Kawasaki's unique aluminum monocoque design, its frame is lightweight and very strong. By utilizing this frame technology, engineers were able to concentrate on delivering a slim, compact package.
Offering a very relaxed sport riding position, the ZX-14 is compact without being cramped, and its bars are positioned so riders don't have to stretch to reach them. The narrow engine, monocoque frame, and fuel tank make it easy for riders to keep their knees close together in any riding conditions. Footpegs are low-set to give ample legroom and the low seat height and narrow seat front make it a cinch to plant both feet on the ground when stopped. Its comfort levels might make the rider think they are on a dedicated sport tourer, but one twist of the ZX-14's throttle is all it takes to remind them they are on the world's quickest, fastest and most powerful production motorcycle.
Kawasaki engineers and designers have created a motorcycle that turns its Ram Air and fuel-injected engine into the core of a powerful, torque-producing, aerodynamic stunner that will draw attention from onlookers whether on the road, or parked on the roadside.
When the rider is stopped, the motorcycle will be the center of attention. Because the monocoque frame goes over the engine and doesn't protrude through the fairing, the fairing design lines are uninterrupted, giving it a smooth, flowing appearance from front to rear.
Quadruple projector beam headlights adorn the ZX-14's front cowl, with the outer lenses containing high beams and position lamps. Low beams are located behind the two center lenses. The turn signals are cleanly integrated into the fairing and rear cowl, and a LED tail lamp features a unique "V" design. Overall, the ZX-14's aerodynamics remind users that Kawasaki is indeed an aircraft maker.
This blending of form, power, and handling characteristics have delivered a motorcycle with appeal that extends far outside of its high performance audience.
All told, Kawasaki brought its engineering and design expertise to the forefront of motorcycle creation. The Ninja ZX-14 lives up to its Ninja heritage, and far surpasses the competition. The meaning of the word "dominant" has found its true definition.
2007 Kawasaki Ninja® ZX™-14 Features and Benefits
Key Features:
- Distinctive Ninja® styling
- Most powerful production Kawasaki motorcycle to date
- Next generation monocoque aluminum frame
- Comfortable riding position
1,352cc Four-Cylinder, DOHC Engine
- Tuned to provide smooth power across a very wide rev range while raising Kawasaki's legendary horsepower standards to a new level
- Carefully planned engine design keeps it compact and narrow
- Chrome composite plated aluminum cylinder bores are lightweight, durable, and quickly carry heat away from the combustion chamber and piston for supreme durability at high power outputs
Gear-Driven Dual Engine Balancers
- Already in perfect primary balance, dual secondary balancers virtually eliminate unwanted vibrations for extremely smooth engine operation and rider support
Ram Air Induction
- Central Ram Air duct produces a straighter path to the airbox for maximum intake efficiency
- This system takes cooler, high-pressure air from in front of the fairing and guides it through the air cleaner and into the engine for maximum power output
- 44mm Mikuni throttle bodies are fitted with sub-throttle valvesthat are controlled by the ECU to provide precise response and make DFI® performance smoother, with response similar to constant velocity carburetors
- 32-bit electronic control unit works with dual throttle valve system to further enhance throttle response and control
- A digital computer feeds the engine exactly the amount of fuel it needs for cleaner emissions and maximum fuel economy
Digital Ignition
- Digital Timing Advance enhances low-and mid-range power
- Four individual spark plug-mounted ignition coils fire each spark plug independently to achieve the optimum timing for that cylinder at that instant
- ECU includes an idle speed control system for easier starting and warm-up
Radial Pump Clutch Master Cylinder
- Hydraulic clutch features a radial-pump clutch master cylinder for smooth and precise clutch engagement
Next-Generation Monocoque Aluminum Frame
- Evolved from the ZX-12R, the frame is a hollow aluminum box that arches over the engine from the steering head to the swing arm pivot. It is narrow, strong, rigid and very light
- Engine is rigidly mounted to increase the monocoque's torsional rigidity. Plus using the engine as a stressed frame member decreases the frame's weight by approximately four pounds
- Engine positioned forward in the frame, wheelbase and front/rear weight balance were carefully designed to achieve high-speed stability and responsive handling
- Massive head pipe casting contributes to frame rigidity
- The monocoque section houses the air box and air filter in a space-saving design that actually simplifies air cleaner maintenance. Two screws hold a plate on the left side of the frame that allows air cleaner access
- The battery is also housed within the frame and has simple access through the back side of the frame
- The steering head and swing arm pivot areas are cast aluminum for superior strength and rigidity
Inverted 43mm Cartridge Type Front Fork
- Damping rates offer stiff initial action to resist front-end dive when braking
- Stepless damping adjustment improves suspension performance
Bottom-Link Uni-Trak® Rear Suspension
- Linkage rates provide linear suspension action
- The bottom-link design concentrates the weight lower in the chassis for a lower center of gravity, which makes the motorcycle more nimble
Radial Mounted Petal Front Disc Brakes
- Radial mounted four-piston front brake calipers. Instead of mounting the calipers with threaded tabs cast near the top of the caliper, the radial design utilizes integrated mounting points at both the top and bottom of the caliper, with the mounting bolts inserted through the rear of the caliper instead of the side/front. This makes the caliper more rigid, which improves brake feel over a wider range of operation
- A separate brake pad is used for each piston. One large pad can deform with the heat generated by hard braking, resulting in a loss of brake feel at the lever. Individual pads provide increased cooling efficiency and can absorb more heat without deforming so they maintain consistent brake feel stop after stop
- Petal design brake discs provide better cooling and warp resistance
- Radial-pump front brake master cylinder improves brake performance and lever feel
- Wheel rims feature center ribs which are slightly offset so tire balance weights can be located precisely along the wheel's centerline.
Wind Tunnel-Designed Bodywork
- Since the monocoque frame goes over the engine the fairing is uninterrupted by protruding frame spars, adding to the extremely long and low styling. Both the front and rear turn signals are integrated into the bodywork and have clear lenses to enhance the appearance
- Quadruple projector beam headlights give the ZX-14 a distinctive upper fairing. The outer lights contain position lamps and the high beams, while the low beams are in the center lamps
- Lightweight Denso radiator with high-density cores provides maximum cooling efficiency
Full Instrumentation
- Dual analog speedometer and tachometer with white faces are easy to read
- Multi-function LCD digital display includes an odometer, two trip meters, fuel gauge, gear position indicator and a clock
- Programmable shift indicator lamp illuminates at pre-set rpm to signal rider upshift
- Programmable clutch engagement lamp illuminates at pre-set rpm to signal the rider to engage the clutch
- CAN (Controller Area Network) interface between the meter uses fewer wires while allowing a greater volume of information, such as estimated fuel mileage, to be exchanged
2008 CONCOURS
KAWASAKI CONCOURS™ 14 AND CONCOURS 14 ABS: SPORT TOURING WITHOUT COMPROMISE
Supersport performance with long-distance touring comfort
The new Concours ™14 and Concours 14 ABS combine breathtaking engine performance, impeccable handling and a comfortable riding position with clean, convenient shaft drive, locking hard luggage, an electrically adjustable windscreen and a host of other features to create the most impressive long-distance, high-speed machine on the market today.
An aluminum monocoque chassis, radial-mount brake calipers, inverted fork, and ram air induction are all features riders expect to find on top-of-the-line supersport machines. However, instead of riding a high-strung racetrack missile, they can enjoy these high-performance features on Kawasaki's new Concours 14 sport touring motorcycles. They are the first representatives of an entirely new genre of high-performance motorcycle: the Transcontinental Supersport.
Because it's a Kawasaki, the Concours 14 is naturally designed to do much more than just take a rider from point A to point B. Thanks to its sporting heritage, the new Concours 14 is not only an awe-inspiring road burner, it can also carve up mountain roads like a true supersport bike. For those riders who cross state lines the way others cross town, this machine offers more excitement than anything else in its category.
The Concours 14 may be a physically impressive machine, but as soon as riders flip the side stand up, they'll be astonished at the bike's lightweight feel.
The confidence-enhancing ABS brake system (Concours™ 14 ABS) features radial-mount front calipers operated by a radial-pump master cylinder, for the superb control and powerful, reliable braking performance that continent-crossing sport riders expect.. Belying its tourer-like appearance, the Concours 14's phenomenally responsive handling characteristics make the other bikes in its category seem like transports by comparison. This provides the Concours 14 rider with a feeling of complete control for spirited, confident journeys.
In addition to an incredible level of sporting performance, the new Concours 14 has the functional touches of a Grand Touring machine. Features include KI-PASS (Kawasaki's Intelligent Proximity Activation Start System), the first "smart" key ignition system in its class, and an accessory power outlet located near the cockpit for powering portable electronics, grip heaters and other accessories. There's also an electrically adjustable windscreen, shaft drive and detachable, locking side cases, so the Concours 14 is always ready for a high-speed ride to the local hangout or that favorite spot... fifteen hundred miles away.
The Concours 14 is much more than a sportbike with tacked-on touring features; it's an integrated high-speed touring system. Wind protection for rider and passenger is based on a supersport-style design philosophy, aerodynamically curving wind around the riders to reduce buffeting that occurs when wind curls around screens that simply "block" the wind. Additionally, maintenance chores on long-distance trips are minimized thanks to quiet and reliable shaft drive. Featuring a special four-link design, the Tetra-Lever shaft drive system significantly reduces driveline lash during sport riding and helps ensure smooth acceleration when exploiting the engine's incredible power output. In fact, power delivery to the rear wheel is so smooth and so direct that it gives the same natural ride quality as a chain.
The Concours 14's touring prowess doesn't stop there. The included hard luggage features a slim, integrated design which mounts the cases closer to the machine's centerline for excellent mass centralization. Sensors in the front and rear wheels monitor tire pressure and display this information on the instrument panel, giving riders peace of mind during two-up high-speed riding or when carving up a mountain road.
With all the equipment needed for safe and exciting long-distance riding mated to a decidedly supersport core, the new Concours 14 amplifies all the best riding features that motorcycling has to offer. Motorcyclists carry a driver's license, but Concours 14 riders should bring their passports, too.
2008 Kawasaki Concours™ 14 Features and Benefits
Key Features:
- Most powerful production sport tourer
- Comfortable long distance riding position
- Low-maintenance shaft drive
1,352cc Four-Cylinder, DOHC Engine with Variable Valve Timing (VVT)
- Tuned to provide smooth power across a wide rev range
- Variable valve timing improves the engine's flexibility and efficiency by altering the camshaft profiles to suit different rpm ranges
- Chrome composite plated aluminum cylinder bores are lightweight, durable, and quickly carry heat away from the combustion chamber and piston for supreme durability under high loads
- Already in perfect primary balance, dual secondary balancers virtually eliminate unwanted vibrations for extremely smooth engine operation and enhanced rider comfort
Ram Air Induction
- Ram Air ducts produce a straighter path to the airbox for maximum intake efficiency
- This system takes cooler, high-pressure air, guides it through the air filter and into the engine for maximum power output
- Throttle bodies are fitted with sub-throttle valvesthat are controlled by the ECU to provide smooth, precise response similar to constant velocity carburetors
Digital Ignition
- The frame is a hollow aluminum box that arches over the engine from the steering head to the swing arm pivot; it is narrow, strong, rigid and very light
- Massive steering head casting contributes to frame rigidity
Radial-mount Petal-type Front Disc Brakes
- A separate brake pad is used for each piston. One large pad can deform with the heat generated by hard braking, resulting in a loss of brake feel at the lever. Individual pads provide increased cooling efficiency and can absorb more heat without deforming so they maintain consistent brake feel under extreme conditions
- Petal design front and rear brake rotors provide enhanced cooling and better warp resistance
Tetra-Lever Shaft Drive
- Unique four-link design significantly reduces driveline lash during sport riding and provides smooth acceleration when exploiting the engine's incredible power output
- Virtually maintenance free, the Tetra Lever system dramatically reduces routine maintenance requirements
Antilock Brake System (Concours™ 14 ABS)
- ABS brakes boost safety and rider confidence in low-traction conditions and may enhance evasive maneuvering in an emergency
Bodywork Optimized for Sport Touring
- Fairing design promotes smooth airflow around the rider and passenger with minimal buffeting
- Integrated, locking hard luggage offers plenty of storage, without disrupting the Concours 14's style or performance
- Electrically adjustable vented windscreen
- Large, comfortable seat offers long-distance comfort for both rider and passenger
- Glove box mounted on the fuel tank cover
- Easy to read speedometer and tachometer
- A CAN (Controller Area Network) interface between the gauges uses fewer wires while allowing a greater volume of information, such as estimated fuel mileage, to be exchanged
- Kawasaki Smart key system (KI-PASS)
- Tire pressure sensors
NEW 2008 KAWASAKI KLX™450R MODERN OFF-ROAD DESIGN MEETS WORLD CHAMPION MOTOCROSSER
Off-road toughness, electric-start convenience, motocross performance
Kawasaki's 2008 KLX™450R will soon be making a name for itself amongst the growing legion of off-road racing fans. This purpose-built version of the brand's World Supercross Championship winning four-stroke KX™450F motocrosser delivers the same high performance features as the KX model, yet modifies it for the improved durability, comfort, and range needed by off-road racers.
Adapted to the rigors of grueling courses, this model's lightweight engine has been tweaked for more low and mid-range performance delivering a wide spread of responsive, high-traction torque and superior throttle control for low-speed maneuvering. The KLX450R's gutsy response to hill climbing, mud holes, or other poor-traction, low-speed conditions will put it at the top of every racer's "want" list.
Kawasaki engineers have combined revisions in cam lift and timing in order to boost low and mid-range torque. Adding to the special characteristics of this engine are a heavier flywheel with double the mass of the KX450F's unit and a wide-ratio five-speed transmission with gears that have been specifically selected for off-road competition.
Adding an electric starter in addition to its kick-starting capability gives the KLX rider more options in the event of a stall. A high-capacity starter motor and compact, high-output battery helps insure quick and reliable starts under virtually all conditions a racer might face. A simple push of the starter button is all that's required in the event of a stall and can often be accomplished while still moving.
Given the length of some off-road race courses, being there at the end is just as important as getting there quickly. Kawasaki has engineered-in extra durability for the KLX450R, to help make it the envy of all competitive off-road riders. While the lightweight titanium intake valves from the KX remain unchanged, steel valves are used in place of the KX's titanium exhaust valves and the radiator is fitted with a reservoir tank to provide efficient cooling during long enduros. The KLX450R also features a sealed chain.
Utilizing the top-of-the-line suspension from the championship-winning KX450F, this new motorcycle puts extreme off-road capability at the top of its must-do list. The Kayaba AOS inverted fork provides superb damping and steering precision with tuning specifically optimized for light, easy handling characteristics. Oil and air are kept in separate chambers for stable damping performance during long events and low-friction seals contribute to smooth fork action.
Rider fatigue can be a significant factor in the outcome of an event, or just a weekend play ride, and Kawasaki has taken steps to minimize this bothersome effect. The KLX450R's chassis has been specially set-up to be nimble while negotiating narrow trails or maneuvering between rocks and trees. The wider seat with slip-resistant top surface adds both to comfort and mobility, while the 18-inch rear wheel allows for use of a taller/thicker rear tire which is more suited to absorbing sharp-edged impacts and allows the rider to choose from a wide selection of off-road tires.
A lightweight digital instrumentation cluster includes speedometer, twin tripmeter, odometer, and clock. The plastic fuel tank, which meets all environmental regulations, has a 2.1 gallon capacity and the petcock is fitted with a reserve. Illumination equipment is also kept on the light side, with the 35 watt compact headlight using a plastic lens, while the ultra-compact and energy efficient LED tail lamp highlights the part of the KLX450R that most other competitors will see.
Among the other race-ready features of this new motorcycle are: side covers shared with its motocross brother, though purposely lacking any holes so that water can't seep in; a left-side cover made of two pieces with a special "door" that allows easy access to the air cleaner; engine guards for both sides of the engine; and a works-style aluminum skid plate. All told, this new Kawasaki is ready to get dirty.
This straight-from-the-factory racer has everything needed to both maneuver an open course and find its way to the winner's podium. Every component found on the new KLX450R has been developed to enhance off-road racing performance while adding as little weight as possible. In fact, a fully-equipped KLX450R only weighs about 22 pounds more than the KX450F.
2008 Kawasaki KLX™450R
Ultra-powerful 449cc Liquid-cooled, Four-stroke Single
- 449cc liquid-cooled, four-stroke single with four valves
- Features improved low and mid-range power delivery for climbing hills, riding in the mud or other poor-traction, low-speed conditions
- Linear power curve offers plenty of over-rev, for maximum flexibility in choosing shift points
Top End
- Revised cam lift and timing boost low- and mid-range torque
- Camshaft lobes and tappets feature a soft-nitride surface treatment for long wear and high-rpm reliability
- Hand-finished surfaces of the polished intake ports improve intake efficiency at all rpm
- Lightweight 36mm titanium intake valves and aluminum valve retainers reduce reciprocating weight for reliable valve control at high rpm
- 30mm steel exhaust valves replace the KX's 31mm titanium units for improved durability
- Double valve springs help ensure stable valve operation
- Screw-type automatic cam chain tensioner with oil pressure spring
- Revised ignition timing helps boost power
- Low-friction coating on piston skirt
Bottom End
- Flywheel mass is double that of the KX450F to provide ultra-smooth engine power characteristics
- Crankshaft, rotor mass centralization, oil circulation, and ignition timing have been carefully examined to help ensure ideal engine braking characteristics
- Crankshaft and connecting rod are sintered for additional rigidity
Exhaust
- Large 41mm titanium exhaust header for maximum power
- Tapered exhaust pipe joint helps increase ultra-low rpm power.
- Titanium exhaust pipe heat shield
- Silencer uses long-fiber packing for lower maintenance
Cooling
- High-capacity Denso radiators deliver superior cooling efficiency
- A reservoir tank is fitted to the radiator, for efficient cooling during long enduros
- Slim radiators feature tightly packed cores and fins designed to enhanced heat dispersion
- The KLX radiator shroud design is optimised for a seated position, compared to the KX shrouds
Electric Starting
- High-capacity starter motor is compact, yet offers high-output to help ensure quick and reliable starts under all conditions
- Lightweight battery is located beneath the seat and behind the airbox for optimum mass centralization
- Having both electric and kick starters means the KLX450 can be quickly restarted if the engine stalls during an event
- Features highly reliable auto-decompression system; the dual-weight centrifugal decompression system fitted to the exhaust cam eases starting, and its simple construction helps to ensure reliability
ZXRaven
posted September 23, 2006 08:19 AM
Damn, i love that new 6R! Really cool!
HiMile14
posted September 23, 2006 08:31 AM
Great post,
and late again to the table.
posted September 23, 2006 08:33 AM
Great post,
TJ
posted September 23, 2006 08:42 AM
Thanks for posting all this info
frEEk
posted September 23, 2006 08:52 AM
really like the colour schemes ont he 6 and 10, specifically all the blacked out bits. makes the bikes look clean. 2008 sure looks to be the year Kawasaki cleaned out the closet with the ancient KLR and Concours getting some work done. Bravo on both, especially the concours. Can't wait to see full specs on that.
GUNNER
posted September 23, 2006 08:53 AM
Once again the fine folks in the paint dept at Kawasaki are completely on CRACK!!!!!!!!!!
GUNNER
posted September 23, 2006 08:56 AM
WHO in their right mind would be caught dead on that white a FAG flamed 14?? Where's the GREEN 14 KAWASAKI?????????????? Where????
frEEk
well yes, on the paint itself i'd agree, or rather all the flames. but hey, some people are gonna like it, and as long as i got a non-flame option, i'm happy.
WARBIRD
posted September 23, 2006 09:04 AM
Thanks for the pics. That white 14 is Hidious!!! Thought for sure we would see a green one. I like the red 10R..........looks nice. Would like to see the front of the GTR1400.............
I'd Rather Be Roadracing.
princesskiwi
MISTRESS of SMACK
I don't know - lots of people ride around with painted rims....I never thought that was a good look, but the guys who own those painted rims seem to like it - so why not a couple of flames?
A consumer version of a 'custom' bike.
princesskiwi
MISTRESS of SMACK
posted September 23, 2006 09:06 AM
I could have a new 6.
A black one......
princesskiwi
MISTRESS of SMACK
posted September 23, 2006 09:08 AM
I could also spend some quality time on the CONCOURS, ride it through Death Valley - try to make it to Mount Rushmore.
GUNNER
posted September 23, 2006 09:09 AM
Custom means ONE of a kind!!!!!!!!!! The world can handle one ugly anything at a time, BUT these are mass produced!! I'm feeling sick
KAWASAKI........................Do you HATE American's?? Why do we NOT get a Green 14?? Why? WHY? WHY?
GUNNER
posted September 23, 2006 09:13 AM
A black one......
The new 6 is very smokin HOT!!!!!!!!! I want to see how the tail light is situated though. If it's attached to the rear mud flap it will be hard to clean up the rear. The new Honda 6 is that way and it's going to be hard to take off that R6 lookin rear fender.... THe after market will have their hands full with that design.
WARBIRD
posted September 23, 2006 09:15 AM
I really like the wheel/lower fork leg color on the 14 this year. Much nicer than last year...............
GUNNER
posted September 23, 2006 09:18 AM
Black wheels would have been a huge improvement still. I like the lower leg being Black as well.
WARBIRD
posted September 23, 2006 09:26 AM
Yes black would have been best. MUCH better than last year though.
WARBIRD
posted September 23, 2006 09:29 AM
"I don't know - lots of people ride around with painted rims....I never thought that was a good look, but the guys who own those painted rims seem to like it - so why not a couple of flames?
A consumer version of a 'custom' bike. "
That's exactly right.............
WARBIRD
posted September 23, 2006 09:33 AM
Thanks again for the great post you all................or "yall" as they say here in Kentucky. It has rained 6.5 inches the past 24 hours and the strong storms and rain are moving in right now. 2 to 4 inches per hour expected as well as tornados. It's great to be able to read and enjoy this post today. Perfect timing in my opinion............
WARBIRD
posted September 23, 2006 09:37 AM
What do you have to do to get on Concours14.com?
posted September 23, 2006 09:44 AM
type in "www.concours14.com" and hit "enter" ?
FasterThanStink
posted September 23, 2006 09:45 AM
What's the price of the Concours 14?
That's what gets you.
FasterThanStink
posted September 23, 2006 09:49 AM
It says This forum is private, and you are not allowed here. Sorry!
I know when I am not welcome.:Cry:Cry:P
WARBIRD
posted September 23, 2006 09:59 AM
Is that a question???? Are you answering my question with a question?
I get that "your not welcome here" message too.
All times are America/Va [ This thread is 5 pages long: 1  2  3  4  5     Next» ] < Previous Thread     Next Thread >
0.26075911521912 seconds processing time
