BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Yosh System experience on a ZX-12R NEW TOPIC NEW POLL POST REPLY
iflyguns
posted February 26, 2002 06:22 PM
I like the way the Yosh stainless with a Oval TI can looks, the RS3 System. I am considering buying it due to the fact that I'm getting a hell of a deal for it brand new still in the box! Will it give me the same amount of power as the others will or more. I plan on putting this system on in conjunction with a PCIIIr, BMC Filters and an ignition advancer. I am hoping for 175-180 hp on the dyno. Any ideas or suggestions.
_________________
Thanks,
Tony
Tony D
RocketRacer
posted February 26, 2002 06:30 PM        Edited By: RocketRacer on 26 Feb 2002 18:41
Several of the board members have the Yoshimura RS-3 Duplex Race systems on their bikes - Y2KZX12R, Ninjaman12R, Otis, FearsomeK, Hondo and myself to name a few. I think you'll find we all love our Yosh exhausts. The Yosh RS-3 Duplex Race and the Akrapovic systems are at the top of the heap for street systems in my opinion. [Not that my opinion counts for much! ]
Just make sure that the RS-3 system you are looking to buy is in fact a Duplex Race system. Yosh also makes the RS-3 system with a "non-Duplex" header for the 12R. The correct part number for a system like you described (stainless system with Titanium canister) is ZX126RRD-TI.
iflyguns
posted February 26, 2002 06:43 PM
Hey Rocket thanks for that info!!!! I need to check. Whats the difference between the two?
Tony D
RocketRacer
posted February 26, 2002 06:48 PM        Edited By: RocketRacer on 26 Feb 2002 18:53
Well, the Duplex Race system is technically a "race" system, while the regular RS-3 system is a "street" system. The regular system doesn't have the cross-over tubes on the header pipes and (I'm guessing here) the headers are probably a little smaller diameter. I believe the regular RS-3 system also comes with a more restictive "street" baffle in the canister.
I'm not 100% sure what the differences are (aside from the cross-over tubes) since NO ONE that I know of has the regular RS-3 system!!
iflyguns
posted February 26, 2002 06:58 PM
It is the Duplex race system. Is it unrealistic to expect 175-180 from the mods I'm talking about and have any of you guys dyno'd. Also do you run PCIIIr or the Yosh EMS. Where did you guys get your maps.
Thanks Again
Tony D
RocketRacer
posted February 26, 2002 07:07 PM
Thanks Again
175-180 is not unrealistic, but those numbers can vary quite a bit from dyno to dyno! A "happy" dyno will post somewhere around 180 RWHP with the Yosh Duplex, a Power Commander (or Yosh EMS) and K&N filters.
I run the PCIIIr on mine and the K&N filters. The bike ran good with the mapping available from Dynojet, but I had a custom fuel map done on a DJ250 and the engine is much smoother running. Check the Power Commander website to find a complete listing of "authorized" Power Commander Tuning Centers.
RocketRacer
posted February 26, 2002 07:23 PM
"I plan on putting this system on in conjunction with a PCIIIr, BMC Filters and an ignition advancer."
You DO realize that the PCIIIr allows you to advance/retard the ignition timing? No need for a mechanical ignition advance unit when you've got the PCIIIr!!
iflyguns
posted February 26, 2002 07:28 PM
No I didn't know that! Is there anyway you could send me a copy of the map you used?
iflyguns@earthlink.net
Tony D
RocketRacer
posted February 26, 2002 07:41 PM
Yes, I'll send you the custom fuel map. The ignition timing map that will come with the file I send you is "Hank's ignition timing map". It works well for most of us that have tried it. Check your mail soon!!
iflyguns
posted February 26, 2002 07:44 PM
Thanks Rocket!!!
Tony D
RocketRacer
posted February 26, 2002 07:52 PM        Edited By: RocketRacer on 26 Feb 2002 19:54
It has been sent. You will need to have the Power Commander software on your computer to view the maps (tables). If you don't already have the software (it comes with the Power Commander when you buy it), you can download it free from the Power Commander website.
I'll be back in a little while --- got to prime some .223 Remington cases!
Koz
posted February 27, 2002 05:10 AM
The 12 with a decent pipe, filters, PC3/r, and the Dynojet map specific for your set-up should produce 170+HP. Now if you purchase one of the leading pipes such as akro, Ti Force, Yosh, and of course the bad-ass sounding Muzzys, with the rest of the above mentioned parts you should see 175+HP. As far as PC3r or EMS, here's the deal, They both do the same thing, they allow you to control the air/fuel mix and timing advance. Therefor, with either you will not need a advancer. Actually Dynojet makes both. The difference is the EMS has options that allow all the bells and whistles for an additional cost (Up to approx.$1000). The only thing I would want to know, does the EMS link to the automated tuned link computerized tuning system used with the PC3/r. If not I'd rather buy the PC3/r and add the other bells & whistles separately. Take a look at this system, http://www.powercommander.com/tuninglink.shtml
If you use one of the top pipes and the above-mentioned parts with the Dynojet Linked Tuning you should see closer to 180HP.
I personally think that with the full ti/oval Muzzys you get more for the money. It's right up there with the peak HP producers, it's probably better in the mid-range then most, it's probably the lightest pipe made, it's one of the most reasonably priced, and it is definitely the most Bad-Ass sounding pipe. As far as quality, I'd put the full ti/oval Muzzys up against ANY pipe.
Koz
Ninjaman12R
as a Deal's Gap tour guide.
posted February 27, 2002 05:50 AM
I love my Yoshimura......
It kicks ass.....PERIOD!!!! Excellent bottom, and killer midrange and topend pull. I'll go with Koz on the Muzzy as far as sound goes. I like that deep as rumble they get, but my Yosh is coming into it's own now that it's getting a few miles on it and I like the sort of exotic sports car sound it makes too. Plus for a goddamned idiot like me, it will draw a little less attention.
I am glad I went the yosh route because I was SO afraid a full system would yield a "peaky" power delivery. Not so with the yosh, it pulls hard everywhere, and that's the way I like it. I know some pipes really give up some power on bottom then come on in the mid, I didn't want that. I looked at dyno charts long and hard before I bought the Duplex system. Plus I've rode a muzzy piped 12 and noticed it was mild down low (no offense Muzzy guys, you know I like muzzy products) and I didn't care for that. I'm a wheelie freak, curve rider, and the fatboy who occasionally goes to the strip on test and tune night. The yosh suits me fine, I think anyone would be pleased with it.
zx1012r
posted February 27, 2002 10:47 AM
Rocketracer, Can you send me your map too? Just got my system and want to play around. Thanks
RocketRacer
posted February 27, 2002 04:20 PM
I'd gladly send it to you - but I don't have your e-mail address!! My map can also be downloaded from Easyrider's website. It is the "Red 12R Rocket" map over on his site.
zx1012r
posted February 27, 2002 07:57 PM
Thanks Rocketracer. I downloaded the map from Easy's site. Your mods are identical to what I have so hopefully it will work nice without me having to have it tuned.
RocketRacer
posted February 27, 2002 09:00 PM
That's cool!
iflyguns
posted February 28, 2002 01:57 AM
Thanks for all the help!
Well just bought a brand new system for my 12 today. A Yosh Tri oval Duplex TRS Race Stainless Steel Full System w/Titanium Sleeve. Should be here next week. Can wait! Now for the EMS vs. PCIIIR issue. Which one to buy and why! :-)
Tony D
Ninjaman12R
posted February 28, 2002 05:08 AM
You'll like it.........
You'll like the Yosh. It's a nice system,almost to pretty to cover up. But it ain't the looks you'll be thinking about after your first ride. You'll be going D-A-M-N!!!
Engage
posted February 28, 2002 01:24 PM
Who has the best prices on Yosh?
Y2KZX12R
CompetitionCNC.com
posted February 28, 2002 07:37 PM
Depending on some dyno testing you Yosh 126rrd guys might have some more "bolt on" low end snot coming your way in a month or so. We'll see how it goes on the dyno.
Y2KZX12R
CompetitionCNC.com
iflyguns
posted March 01, 2002 02:21 AM
Best Price's on Yosh
Engage,
I got a killer deal on mine that's why I was so quick to buy! I paid $395 which, is 75% off the retail price. That was a one time deal! The best price was Ken's Cycle Center ask for Craig. That is the only place I do business he bats everyone prices on everything and is very legit!
Kenscyclecenter@aol.com
Tony D
mopar426
posted June 30, 2009 08:09 PM
hello rocket racer,
i've been unable to find the correct easyrider site, do you think you could send me your " red 12 R rocket map"?
or the easyrider website address?
thanks for your help
kind regards,
mopar426.
canadian mike
posted July 01, 2009 04:54 AM
that post is 7 years old......
01 zx12
03 TURBO BUSA
maddfayce
SARR SGT@ARMS
posted July 01, 2009 08:32 AM
http://www.hardracing.com/Exhaust%20Systems/Yoshimura/Kawasaki.htm
Pretty much cheapest I have found so far for the Duplex online.
0.26367092132568 seconds processing time
